Question about Frigidaire GLWS1749A Top Load Washer
Water is not flowing to machine neither hot or cold.
    Problem Solver:
  • 15 Answers
If it agitates with no water in it the water level switch is the problem.
Sometimes it can be fixed by disconnecting the small hose that runs up from the bottom of the outer drum and blowing it out.
Posted on Feb 05, 2010
Why would the hot water cycle of my washing machine not work?
The solenoid that opens to admit hot water is either defective or not being energized by control panel.
Jun 20, 2017 | Washing Machines
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
The hot water not flowing into the washer and the cold water flows fine?
Let's think and work this one thru:
Your machine probably has several temperature settings, right?
So-- when you set it for COLD-- it fills at the normal rate?
When you set it for WARM-- does only COLD water still only come in?
And if you set it for HOT-- Nothing comes in?-- correct?
Now lets get to the pipes in the back:
Is there a Laundry sink, or a hose or something nearby, so you can be sure you have HOT water to the Washing Machine?-- Is the Hot water flowing good and strong nearby the WASHING MACHINE-- WHEN YOU TEST IT?
And the Valve is not shut at the Washing machine-- (Hot shut, but cold open?)
If you are sure that you have a good supply of HOT water to the machine,--- If you have tested that you actually have a good flow, -- say with the Hose removed, and you run the Hot water into the machine (by-passing the internal control valve!!)--
Then it sounds like: Either the control is not telling the internal solenoid valve to open-- or the valve needs to be replaced.
Do you want to attempt this repair-- or do you want to call for help at this point?
Let me know what you find-- and how far you want to go by yourself.
Mack B
Dec 30, 2010 | Washing Machines
Water fm the cold side have very low flow. have check the hose for clog..clear. check the supply. strong. when the sector switch in the hot or hot/cold water flows but on cold low flow. unit is...
You need to replace the water inlet valve. Since you confirmed that the hot water side works fine, the cold water side is not allow a good water flow. It is a relatively easy repair. The part can be obtained a any local appliance supply house or online. To repair, disconnect the supply hoses to the machine, remove the back panel and the part is behind the panel. Hope this helps you.
Nov 08, 2010 | Whirlpool Washing Machines
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
COLD WATER IS RUNNING SLOW INTO WASHER. THERE IS PLENTY OF FLOW IN THE HOSE AND NO KINKS AND THE SCREEN IS CLEAN. HOT WATER FLOW IS FINE. WASHING MACHINE MAKES A GROANING NOISE WHEN COLD WATER IS ENTERING.
Based on your description, the selenoid is bad.
The same device feeds both cold and hot water - so locate your machine model number and year.. and look up the replacement incoming water selenoid part number. You will need to purchase it and replace it.
If your machine is under warranty, call their Customer Service line and report the water flow/noise problem.
Please let us know your findings...
-Jim
Oct 17, 2009 | Washing Machines
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Aug 15, 2009 | Washing Machines
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
No cold water flow
TRY CHANGING THE COLD WATER TAP IN THE MACHINE.
Oct 13, 2008 | Washing Machines
Frigidaire GLWS1749A Top Load Washer Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
