Question about Kenmore Washing Machines
KENMORE 92588210 washing machine
Upon inspection it appears the brake is not releasing. What do we have to do to get the spring to pull the brake back?
    Genius:
  • 1,122 Answers
If it is a top load you can try jerking the tub in a spinning motion,most of the time this releases the brake
Posted on Feb 05, 2010
Passenger rear brake is frozen or stuck, how do I remove it to inspect springs
On drum brakes there are two reasons for the drum sticking....
the first is excessive dust buildup. This can be loosened by tapping on the edge of the drum with a hammer or mallet. Not too hard though. The other issue is that over time the inside of the drum will get a wear ridge on the outer edge of the drum and this catches on the brake shoes. Sometimes aggressive pulling can remove it. Otherwise, look at the backing plate of the brake assembly. There is usually a slot near the top (or bottom, depending upon where the self-adjuster screw is). You can insert a screwdriver in here and manually back the adjuster screw off to loosen the brake shoes inside the drum. This will allow removal. Remember though, that after inspection, when you replace the drum, you will need to readjust the self-adjuster back out to where it is close to where it was before. Otherwise, you will have uneven rear braking until the self-adjuster compensates, and that can take a while.
Oct 11, 2015 | Cars & Trucks
Jetta parking brake
Your car should have an E-brake engage/release lever. Please inspect the push button on the end of the lever. Does the button depress and release correctly? My guess is that the lever needs to be repaired or replaced. Maybe the internal spring has broke and the button wont release. If the button doesn't release, the ratchet wont engage. Write back and let me know what you found or if you have other questions, good luck.
Mar 28, 2014 | 2007 Volkswagen Jetta 2.5 Sedan
Brake pedal
go to rear of car and wiggle, pull, push on the cables that go into the rear brakes. Sometimes this is all that needs to be done to release the brakes, then I suggest lubricate the brake cables, and/or inspect rear brakes. If this don't help, you could try to use some warm water and pour it over your brake drums, as snow and ice can freeze them up. Try a hairblower if its below freezing. If your brakes are not locked up, make sure your pedal return spring is working properly, sometimes its on the pedal, but most times its under car attached to the cables somewhere.
Dec 16, 2013 | Cars & Trucks
Rear brakes
Removal
1.Remove rear wheel and tire assembly from vehicle.
2.Remove rear brake drums from hub and bearing assemblies after loosening the two brake drum screws.
3.Be sure that the parking brake pedal is in the release(most upward) position.
4.Completely loosen square nut of the rear parking brake cable. Then create slack in the rear parking brake cables.
5.Remove adjuster spring from adjust lever and brake shoe.
6.Remove adjust lever and turn the adjusting wheel of adjuster assembly to the direction of the arrow as shown.
7.Remove the strut spring and the lower retracting spring from the brake shoe.
8.Remove the upper return spring from the brake shoe.
9.Remove brake back plate hold down spring and pin from the leading brake shoe assembly.
10.Remove the leading brake shoe. Then remove the adjuster assembly, strut and anchor spring from the trailing brake shoe.
11.Remove the trailing brake shoe from the brake back plate after removing hold down spring and pin.
12.Remove the trailing brake shoe from the rear parking cable.
13.Remove parking pivot lever from the leading brake shoe.
Replacement
1.Lubricate the eight shoe contact areas on the back plate and anchor.
2.Install the trailing brake shoe to the rear parking cable.
3.Install trailing brake shoe on brake back plate and install the trailing brake shoe hold down spring and pin on the brake shoe.
4.Tighten the square nut of rear parking cable.
5.Install the anchor spring then install adjuster assembly, and strut.
6.Install leading brake shoe on brake back plate.
7.Install the brake shoe upper return spring, strut spring and the lower retracting spring to the brake shoe.
8.Properly rotate the adjusting wheel of adjuster assembly to the direction of the arrow in as shown.
9.Install the adjuster spring on the adjust lever and leading brake shoe assembly.
10.Install the leading brake shoe hold down spring and pin on the brake shoe.
11.Adjust brake shoes assemblies so as not to interfere with brake drum installation.
12.Install the rear brake drums on the hubs.
13.Check and adjust whether the pedal stroke in the specification.(Refer to section BR Gr./On-vehicle service/Pedal stroke of parking brake)
14.Install wheel and tire.
15.Push the parking brake pedal to the floor once and release pedal. This will automatically remove the slack from and correctly adjust the parking brake cables.
16.Test the vehiche on the road. The adjust will continue the brake adjustment during the road test of vehicle.
Inspection
1.Inspect the disassembled parts for wear, rust or damage.
2.Measure the thickness of brake shoe lining.
Standard : 0.17 in (4.5 mm)
Minimum : 0.04 in (1 mm)
3.If the shoe lining is less than minimum or shows signs of uneven wear, replace new one.
4.Measure the inside diameter of the brake drum.
Standard : 10 in (254 mm)
Maximum : 10.07 in (256 mm)
5.If the inside diameter of the brake drum is more than maximum or shows signs of uneven wear, replace new one.
6.Inspect the lining and drum for proper contact. If the contact condition is improper, repair it with a grinder or replace the brake shoe assembly.
Aug 14, 2013 | 2002 Kia Sedona
KENMORE WASHER MODEL 110 92588210 DRAINS WATER DOESN'T SPIN
You might have an issue with the spin gear in the gearcase.
May 31, 2012 | Kenmore Washing Machines
Brake on poulon chainsaw 18"
The brake on this machine is a knee link design, this is an over centre catch, if there is excessive dirt under the over centre mechanism it will not lock properly and so come on prematurley, you need to remove the brake from the machine, activate the brake to release most of the spring tention,remove the hand guard fixing screw and collers, remove the hand guard carefully remove the screws securing the spring cover, be aware there is a compression spring under here, inspect the internal components, clean out any accumulated dirt and debris, replace the cover and hand guard, load the brake by pulling the hand guard fully back, the other option is to just replace the complete brake assembly part no. 530054740
Aug 29, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
When i pull the ebrake and then release it its staying on i have replaced the handle and the main cable from the front to the rear and its still sticking what do i do???? Thanks Travis
adjustment is out, start at rear brakes inspect cable action with wheel off and observe action when handle is engaged. it might have a broken spring there, the handle also has a spring., release brake and use screw driver to push back brakes ,take slack out of line at adjuster and that should be your adjustment. if it gets stuck again its at the brake caliper, wheel cylinder or hardware depending on make and year of car.
Apr 01, 2011 | Chevrolet Cavalier Cars & Trucks
I have a Kenmore Ultra Fabric Care Heavy Duty 80 Series, Model # 92588210, Stock # 25882 that is off balance on every load. After the last few loads the bucket is leaning toward the front. What could be...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11092588210/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Jan 05, 2011 | Kenmore Washing Machines
I pushed on my parking brake and something snapped, resulting in my brake pedal pressed to the firewall,when i pulled the release latch it would not come back up,i pulled the pedal up manually but now i...
if you know someone with a lift, get it up in the air and take a good look. it should be immediately obvious which end or which cable has failed. i think you will find there are two cables in the rear which meet one coming from the front at a central threaded rod adjuster. common for them to become rusted and break at pivot points, swivels, backing plates. it is not unknown for an independent muffler shop to put your vehicle up on a lift and let you take a quick look for 10 bucks or so.
Dec 08, 2010 | 1995 Ford F150 Styleside Regular Cab
Washing Machines Logo
199 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
