Question about Gateway FPD2185W 21 in. LCD Television
No Picture on LG Tv. it is only 3 months old. I
No Picture on LG Tv. it is only 3 months old. I have noticed that the power light flashes five times
  • 755 Answers
The flashing may indicate a failed power supply. Or a bad backlight tube.
Only 3 months old? Any warranty?
Considering its age I would say a defective part or poor assembly is to blame.
Posted on Feb 05, 2010
Try disconnect main supply, then reconnect.
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
Our tv is about 3 years old. We are a Time Warner cable customer. About 2 months ago we started to notice that the picture took a ong time to appear after turning on the set. The sound played for about...
I'm sure this is fairly easy to repair. It sounds likely to be a power supply problem, possibly due to bad capacitors. Your original symptoms of no picture were likely to be the backlight controller not having sufficient power to operate correctly. Ideally you should have it looked at and repaired then because leaving it to get worse may well have caused additional component failure. Get it checked by a reputable TV repair engineer.
Feb 27, 2011 | LG 32LC7D Television
LG 19 LH 2000 no picture or sound
i have exactly the same problem and my tv is just 2 weeks old !!
any soloutions?
Nov 21, 2009 | LG 19LH20 19 in. LCD HDTV
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Degrading picture with my Dwin projector
the colorwheel is going bad and needs replacing. the colorwheel needs to spin fast enough to sync up with the dmd chip. if it cannot, the pic goes bad then off. the flashing is the colorwheel trying to catch up.
Jul 05, 2007 | Dwin TransVision 3 Plus Multimedia...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
No picture no sound
If its only a few months old , get the bill of sale and go to the authorized repair shop. If no warrantee then your gonna have to take it it anyway, as there are no user serviceable parts inside this tv as its solid state and all the parts are soldered in. Your problem could be a cold solder connection on the horizontal drive transformer, or a bad horizontal output transistor along with the HI-Voltage transformer. Like I said If you have no experience with tv sets, this repair should be handled by a pro. Good Luck
Jun 24, 2006 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
196 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
