Question about Roseart Toys
I lost the direstion for the pet stepping stone. How much water to add and can i reuse the mold? How to take out of mold
How do I change kgs to read Stones and pounds?
Let's first convert kg to pounds, and then convert the pounds to stones and pounds.
Start with 75 kgs. To convert to pounds, we multiply by 2.2, or double the amount and add 10% to it. I get 165 pounds.
The next step is to convert the 165 pounds to stones and pounds.
There are 14 pounds in a stone, so we divide the pounds by 14. In this case we get 11 stone with a remainder of 11 pounds.
I hadn't heard this term until I visited the British Isles and one of my co-workers was told he was 3 stone overweight. His nickname became "3 stone."
Good luck,
Paul
Nov 17, 2015 | Office Equipment & Supplies
I have a Magic Chef MCCF7 recently mold has been building up around the seal. the top when closed is very light and you can literally open it up with one finger. what can I do so I don't loose the food...
Use rubber gloves and wipe the seal with a cloth soaked in a diluted bleach solution (20 parts water to 1 part bleach). Let the seal dry. Chest freezers don't lose much of their cool when open so you won't have to worry about losing the food while you are working on it. Close the freezer and let it sit for 30 minutes then repeat the above steps until the mold is gone.
Feb 28, 2011 | Magic Chef 7 cu. ft. / 198 liter Chest...
Do you fill with cold or hot water for vicks warm steam humidifier
im pretty sure you fill it with cold water...at least thats the direstions for when you use the vicks medicine you can add in...works great by the way
Feb 28, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Do & Discover Crystal Growing kit came with 2 spanish ONLY directions...How do we get the right dirsctions so my son can Do & Discover?!
I patiently used Google Translate and got this. The instructions may not be in perfect English, but it's good enough to understand. Good luck :)
GROWING CRYSTALS
1.
experiments require a large measurement cup (at least 32fl oz / 0.9 1) Heat resistant glass mix the powder and boiling water. The vessel measures must be glass or plastic Resistant to heat. You also need a medium saucepan (at least 32 fl oz / 0, 9 1) to boil water. Separate carefully cut molds, as pictured. Make sure to leave a border around each mold. Also remove sharp edges from the edges with scissors.
2.
Use a large glass measure (at least 32 fl oz / 0, 9 1) (not included) to measure 0.68 liters of water and pour into a medium-size saucepan. Heat the pan until the water boils.
3.
Open the bag of potassium sulfate 10 (diamond frosting) with chemical crystal growth and pour the contents into the glass of measures.
4.
Pour boiling water in medium saucepan shot glass with the contents of the bag 10.
5.
Stir the mixture with the big stick until all the grains are completely dissolved chemicals. NOTE: Let the mixture cool for 5 minutes after the grains have dissolved.
6.
placed 2 rocks on the bottom base of the 5-sized plastic molds "C" of growth. These basement rocks should rise only about 3 / 4 "(2cm) from the bottom of mold growth.
7.
Pour the chemical solution / water shot glass molds in size 5 "C" for crystal growth. Make sure to fill each mold in the same way, leave an inch (8mm) of space between the liquid and the edge.
8.
After removing the bottle cap coloring dye, carefully cut with scissors (not included) the tip of the boat. Individual drops slowly drops of dye into the mold of crystal growth. see diagram following Mercedes to mix colors. Once you add the dye mixture solution with the small mixing stick. NOTE: Do not add dye to the mold of a glass. transparent crystals are better for the electronic.
9.
Place the mold of crystal growth in a place where not disturbed by movements or changes in temperature. crystals begin to grow in a matter of hours. let the crystals grow for three or four days without disturbing them. You can then remove the crystals from the solution. For best results, wash the crystals abundantly in the sink to remove excess dye and place on a newspaper or paper towel for a day to dry.
10.
if the mass of rock crystal and the base have been a square shape due to the structure of the mold growth, you can break the remaining crystals that form the block so that the crystalline mass display look more natural from the geological point of view. to expose the glass, LED lights the base by pressing the button on the bottom. transparent glass placed at the base and see how it changes color. if you are not using the base, be sure to extinguish by pressing the button again. to replace the battery, remove the cover with a screwdriver as shown below. NOTE: with the help of a magnifying glass, look closely at the detailed crystal structure of the crystals finalized.
Beak-shaped crystals: follow steps 2-10 with the following changes: In step 2, only 0.34 a boil water. In step 3, use the contents of the bag 11.
In step 6 uses the five molds size "D" of growth of crystals with a single rock in each base.
In step 8 uses color guidelines mold "D" (crystals spike) in the diagram below.
NOTES: replacement of the battery base. Place the base upside down. Now you can remove the battery cover to access it, as shown in the image below.
Jan 10, 2011 | Edu-Science Toys
We have a rock tumbler and have lost the instructions. How long are we to tumble each stage? I assume that the sand goes inside the tumbler with the rocks. We need some directions.
Fill the barrel most of the way with stones, add coarse grit, add enough water to just cover the stones and then clean where the lid seals carefully. Seal it up and run it for a week, dump everything into a colander and rinse. Don't run that mud down your drain because it will plug it mightily, run it outside.
Do the same process with the fine grit, run it for another week and rinse and admire.
lp
Jan 02, 2011 | Edu-Science Toys
We lost the creatology rock tumbler instruction manual and cant do anything with out it
Hi, We got the same tumbler this Christmas. You might be able to get an manual from service@bhsciencetech.com
To get started though, Step 1 takes 2-4 days, step 2 4-7 days, step 3 2hrs, step 4 2 hrs.
To start day 1
1) rinse stones with water and fill barrel with no more than 8 oz of stones
2) Add step 1 course Grinding Powder
3) Add enough water to cover stones
4) tighten (snugly) cap on barrel to prevent leaking
5) Be sure barrel is clean & dry. Fit barrel into tumbler (fits correctly only in 1 direction). Cover barrel with safety dome.
6) Attach DC plug to tumbler and plug in.
7) Push on/off button
8) Push # of days button timer.
Extras
They suggest using a lubricant on the inside rim of lid to help removal.
Once you start the tumbling do not turn it off and leave it off - It will harden like cement inside the barrel.
It is loud so place it on a towel to help reduce noise and put it where it won't bother anyone.
Good Luck and Have Fun
Dec 26, 2010 | Toys
Mold
the best thing iv found to kill off mold is,,,"vinegar" white is best! but any will do,,mix up a good drop in a bucket and wash the mold off,,,it kills it stone dead,,, works on any thing you can wash with water too! wood,, walls,,,window's,,,doors,,,inside of boats,,,for your washer tip a bottol full of vinegar into the washer then do a warm wash with nothing in it,,(no washing powder!!!!) just plane water,,,also if when its not in use you could leave the door open thats good as well,,it needs a change of air going around it to stop this mold building up,,, your house may smell a little like a chip shop for a day or so,,but whats best,,,lung problems at a later date????and mold all over your house??? it spreds you know!!
Jun 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
Mar 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Toys Logo
75 people viewed this question
Top Roseart Toys Experts
ray gallant
Are you a Roseart Toy Expert? Answer questions, earn points and help others
