Question about Sony GV-D1000 Mini DV VCR
Sony GV-D1000 unit will not recognize memory stick have two units both memory sticks work in the good unit the bad unit says either no memory stick or memory stick error
2 Suggested Answers
  • 36 Answers
SOURCE: Sony GV-D1000 Powers on, will play memory stik, but not tape
C:31:23 error code means problem is in Supply Reel section.
If you are tech person you might got the point.
Unit has mechanical problem in supply reel area and reel pulse is not being generated as supply reel table may be stuck due to back tension.
Let me know if you need further help.
Posted on Feb 11, 2009
Hi there How can we connect Sony GV-D1000E with MacBook Pro (2010 model) please?
You need a firewire cable.
Most likely a 4 to 6 pin unit unless the Mac has an 800 port, then use a 4 to 9 pin.
Feb 24, 2011 | Sony GV-D1000 Camcorder
Sony gvd 1000 wont work comes up with code c 31.10
The 31 indicates a motor movement problem. The 10 indicates which one. I don't have the manual handy so I can't look up the specific motor movement that is wrong. These units are tricky to work on and are not DIY repair machines. Please seek an authorized service centor for this repair.
Dan
Jan 18, 2011 | Sony GV-D1000 Mini DV VCR
PSP doesnt recognize the memory pro dua ? what do I do to fix
Hi
Is your memory stick detected by your PSP? If not, then there something wrong with the memory. Try out to insert it to other unit to be sure it will works, if it works then the problem is in memory socket. Try to clean it by using a used toothbrush with isoprophyl alcohol, and let it dry then put it back.
Hope it may helps...
Regards,
kaybicks
Feb 26, 2010 | Sony Memory Stick Pro Duo For PlayStation...
Sony gv d1000
Sounds like an exit guide mis-alignment or a worn pinch roller.
Jan 15, 2010 | Sony GV-D1000 Mini DV VCR
My apple computer does not seem to recognise my gv-d1000e when linked via USB. Does it have to be linked via firewire?
Forget USB. Firewire is the best way to link to your Apple computer. Depending on the software your are using you will be able to control your Sony unit from your Apple computer. You could not do that via USB. Also firewire, or in your case i.Link is much faster. Just make sure you have a firewire port on your Apple and the proper software and you should be set. I hope to see your video's on Youtube! : ) Good Luck!
Nov 11, 2009 | Sony GV-D1000 Mini DV VCR
Misfunctioning 4GB memory stick pro duo
Are you formatting it with your computer or PSP?
  1. Push the little HOME button on the bottom left of the face of the unit.
  2. Use the arrow keys to move to the SETTINGS area, then move the up and down keys until you get to System Settings.
  3. Once you are there, click on the "X" button and scroll up and down as needed to find Format Memory Stick. Click on "X" again to select that option.
  4. The Sony PSP will now confirm that you want to reformat the memory stick (which removes every file and game save thereon, of course): choose yes and it'll format in just a few seconds.
It that doesn't work - try formatting it with your computer.
Jul 09, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Feb 11, 2009 | Sony GV-D1000 Mini DV VCR
Sony GV-D1000 unable to be recognized.
launch video editing software...it should be able to see your deck. none of my three macs "recognize" the deck, but finalcut pro sees and can control the deck once it is connected and turned on
Nov 29, 2007 | Sony GV-D1000 Mini DV VCR
Memory Stick Issues
It clearly states on Sony web site that only 32Mb PSP memory Pro will work with SJ20
Jan 19, 2007 | Sony CLIE PEG-SJ20 Handheld
Sony GV-D1000 Mini DV VCR Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
