I am trying to install Windows 7 onto a PC which has no OS installed. The HDD has been pre-formatted. I am installing using a genuine MS Win7 disk and adjusted DOS such that first boot device is the CD/DVD drive with the HDD as second. Both drives are recognised and listed OK in DOS set up pages. All started off OK and when asked I selected Custom Install which was then followed with screen asking where I wanted to install but unfortunately there were no drives listed to select from. When you then try to search for drives you get message drivers could not be found. I checked manufactures web site (Hitachi) to see if one could download a driver for my HDD type HDP725050GLAT80 Deskstar P7K500 but downloads are offered as it states that drivers are standard feature of MS XP, Vista and Win7, not helpful when you do not yet have an OS on your system!! Any suggestions as to how I can resolve this would be appreciated.
  • a_hall6 Feb 05, 2010
    Thanks, can confirm there is only one hardrive installed and jumpers are set so that it is the master. Not sure how I go about deleting and creating partition, can this be done in DOS setup?
  • a_hall6 Feb 06, 2010
    Thanks again, I have removed HDD (nominal 500 GB) and connected to another computer where it is recognised as 'K' drive. Have carried out a Quick Format to make sure am starting off clean then gone to Computer Management(local) then to Sorage-Disk Management where drive 'K' is listed OK. When I click on 'K' it indicates as Disk8 Basic 465.76 GB NTFS Online Healthy (Primary Partition). From this I deduce that it does already have the required partition. Before I put it back into the problem PC is there anything else I need to do? You mention checking the RAM how do I do this?
    President:
  • 3,278 Answers
Hello.
There should be enough drivers on your Windows 7 installation CD to at least install Win 7.
Since you did check your jumpers on the drive so that the drive is set to Master, be certain and that your ribbon cable is OK and snug to the drive.
Before attempting to install Win 7 again, go into your BIOS (usually F1 or F2) and be certain that the drive is present. While there, check your memory to see if the amount is correct.
If the drive is still not present, since the drive and cable are OK (if you used the same cable to test in your other computer), then the IDE connector on the board could be faulty. It's also possible that there is a hardware conflict, thus the other expert suggested that you check the RAM, especially if the amount found is incorrect. Remove both (all) modules and insert one at a time to test.
Hope this helps.
Posted on Feb 06, 2010
  • NinaE Feb 06, 2010
    In addition, I learned that not all motherboards can recognize this drive.
    Novelist:
  • 153 Answers
Try to avoid using the DOS mode in formatting and creating/deleting partitions. Try to use the Windows XP Installer in deleting and creating a partition or other any partition managers (but I recommend XP Installer to be used in managing partitions). After creating the partition using Windows XP Installer, try to reinstall the Windows 7 Operating System and that should do the trick. If you have further question, just reply to this message.
Regards,
sl4x
(Please vote for my solution if it solved the problem)
  • 4,281 Answers
You need to create partition of your harddrive again with FAT32 or NTFS
delete old patition then create new partition.
Also make sure that at least 1 harddrive is set as master with jumper settings.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 05, 2010
  • If your harddrive is recognize in bios and not when you try to install.
    Also make sure RAM works fine .Because if yopur RAM has issue then it not show harddrive during installation.
    You can partition harddrive with partition magic software or connect this harddrive to anther computer then you can partition it there with disk management or my computer .
HP Pavilion TX1000 Series with new 500 gb hdd unable to install windows 7, after partitions on hdd, it disappears, and unable to install os
not sure what "after partitions" means. (ah, at that point in install)
dual booting?
HP disk set
or Microsoft set.?
tell what attempting and where stuck exactly.
what screen , and what error exactly.?
new 500, new in box, new to your or new for an APPLE.
if new, really new it has mfg codes on box for any special pre-formatting...
i bet the new disk is pre-formatted. (or really not new)
seen many new disk in box with antistatic bag breached.
bingo , not really new.
what disk ,? Seagate (best)
windoz hates that, (setup.exe running)
erase the new 500
3 ways.(lots really)
1: put new 500 , as a 2nd HDD in PC #2,
2: with disk-manger delete all partitions on it. its now ready.
A: using boot windows, PE disk, do same in this PC.
B: using boot cd, boot and go to repair mode,(first screen)
then using CMD prompt mode, use DIskpart, to do that.
C: using any bood Linux, live CD same PC, run pparted and erase the partitions.
I can go more, but stop.
All windows install disk, cept w10?>
will erase any windows partitions (if you force it)
but will not do it if the format is ALIEN to MS.
Alien means not fat 16 , Fat 32/ NTFS,
Alien means Apple or other 100s of systems alien to MX.
on windows 10, it will balk with any data there what so ever.
protecting the NOOBs. cure is above.
Apr 11, 2017 | HP Computers & Internet
How can I fix 8002F334 error in my ps3
I've seen this error code going around for the older PS3's. From what I can gather, it's a HDD issue that can't be cured easily. Here are the steps to take that I found, that seem to work for all PS3 systems.
  • take out the hard drive
  • connect hard drive to pc (running windows 7 64bit, but any windows os should work without other software)
  • open up disk management - in win7 it asked me to make a master boot record, so I did.
  • format in NTSF - that's right, NTSF - don't use quick format
  • shut down pc, take out hd, take usb drive too
  • put hd back in ps3, put usb stick in ps3
  • boot ps3
  • a screen will pop-up saying the hard disk have to be formatted
  • hold start + Select for 5 sec.
  • After formatting the system will restart and the update will start installing
  • configure your ps3 setup - done
  • Remember to get the latest firmware from SONY onto the USB drive.
Jan 12, 2016 | Video Game Consoles & Games
Format my hp 635 laptop
Make sure you have all your data backed up
Also make sure you have your re installation disk and proper cd keys to perform a clean install.
power your unit - press F9 for boot options - insert your 7 disk into cd rom and choose boot from CD-ROM. Follow instructions provided from install disk.
Oct 18, 2014 | HEWLETT-PACKARD HP Compaq 635 156 Notebook...
How do i uninstall windows 8 pro from my latop so that i can use my wondows 7 again?
If you installed on the primary drive, not a dual-boot to a separate partition, or booted from a Virtual Box software, you will need a Windows 7 installation DVD/Disk and do a re-install of Windows 7 . Select the primary Drive/partition ,Format HDD, follow on-screen instructions.
Apr 15, 2013 | Lenovo Computers & Internet
When turning on my laptop (DELL Inspiron 1545) the set up starts until I get the message 'BOOMTRG is missing, Press CTRL+ALT+DEL to restart'. Along with this, there is a yellow flashing light
This is an error message your operating system boot manager file is corrupted or missing. A clean re-install may solve the issue. Sometimes you need to format the entire HDD to install the OS. Remove the HDD from the drive bay and connect it to another pc using an external 2.5" case via usb cable and select that HDD from computer and rightclick then format. Select ntfs if needed. Untick the quick format and click OK. it takes a while to finish. After format complete remove the HDD and refit it in your laptop and re-install OS as usual. Hope this helps.
Dec 05, 2012 | Dell Red 15.6" Inspiron 1545 Laptop PC...
How to preserve my genuine windows 7?
use some os installer software u another os can install
May 17, 2012 | Dell Inspiron N4030 2.13GHz 4GB 320GB...
TSSTcorp CDDVDW TS-H. DVD works and can install Win7 thru WinXP. Win7 installation disc boots from dvd. However,after coping pre-install files, installation stops with message that a required cd/dvd device...
This is a problem with the install disk of windows 7 you have i have had this problem in the end i had to download a different copy of the windows install disk off the internet.
This is due to a issue with drivers with that specific dvd drive and a early version of the windows install disk.
Mar 01, 2011 | Microsoft Windows Vista Ultimate Edition
Sony Vaio VGN-AR71J Windows 7 upgrade issue
The solution which I'm about to provide you will erase all the data from your laptop hence, data backup is what you shall think first.
In order to do a fresh install on your laptop you are first required to format your HDD completely. You are required to delete all the partitions on it and recreate new partitions. Your version of Vista home is not allowing to upgrade to windows 7 because both of them are through Microsoft. You have three options at this stage to completely format your HDD
1. Use a DOS bootable CD. Go to any XP PC. Put a new CD inside it right click on CD driver in explorer select Format and then check on create a DOS startup disk. It will make a dos bootable CD put that CD in your laptop and boot through CD it will take you to command prompt. In command prompt you type format C: then again type format D: do it for all the partitions your laptop has if format doesn't work then you can use deltree command. Once the partitions are formatted you can boot through your Win7 CD and install the OS.
2. Use a linux installer CD. boot through Linux installer CD install linux on your laptop and then install win 7 on it.
3. Use a third party disk management tool through which you can boot and erase all the partitions on your laptop.
Jul 02, 2010 | Sony Computers & Internet
I have a hp pavilion 2120tx with windows 7 and i want to dual boot windows 7 and windows xp [windows 7 first]
You can create a Dual Boot in ur machine....
C: XP
D: or E: or F: as Win7
You need to re-format your disk, back up all critical data in your disk....
once done...boot with XP disk in CD drive....
after format, create multiple partitions....C: , D: , E: etc as per your preference
install XP in C:
once done...start PC and let the machine boot from C: XP...once you get Desktop in XP
install Win7 in D: or E: as prefered....once done..
in the startup screen you will get these 2 options
1 load earlier version of Windows
2 Windows 7
to make Win7 as default, right click on My computer (Win7), Properties / Advancd System Settings / Advanced Tab / Startup and Recovery / Under System Startup - Chose the Default OS by the down arrow and the time to it must be displayed in the startup to chose the OS....by this method you can chose Win7 or Xp to load...make your choice as prefered...
reg
for more info on formating and loading OS visit my site
www.sureshayyar.110mb.com
May 08, 2010 | Computers & Internet
BACK TO XP
if you want to recover the other HDD you must first have an ms recovery...
do you have a ms recovery to your laptop?
Mar 22, 2009 | Microsoft Windows XP Professional With...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
