Question about Canon PIXMA MP780 All-In-One InkJet Printer
My printer won't print. I've done all of the maintenance from the menu. it will print one page after cleaning the heads. but then nothing after that.
    Guru:
  • 239 Answers
Go to control panel \ printers &...\ c if ur printer is set as default printer.
Normally a tick will indicate that...
Posted on Feb 05, 2010
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
My HP Officejet Pro K550 is not printing the cyan (blue) ink. It has a new cartridge. I've run print quality pages and configuration pages -- no cyan shows up. I cleaned the printheads and no c
Do a test print...
assuming you have done multiple print head cleans... if it fails to print ANY cyan, I'd guess the print head is dead... although to be honest im not an expert with this hp printer. if that is the case, it probably isnt worth repairing.
If it does print some cyan, just missing, you may be able to find info, sorry, I cant help you there, on accessing the service or maintenance mode and doing a higher level clean, if your printer supports that.
As a last option, disassembly and soaking the bottom of the print head in cleaning solution /water... overnight, without getting ANY water on any contacts, then re running print cleans.
good luck
in my exp, again, not with this printer, mind you, if a print head fails to print ANY ink for a given colour, the print head is usually faulty.
Hope this info helps
May 15, 2012 | HP OfficeJet Pro k550 Printer
My hp 6500 won't print black. I've changed the cartridge twice. No result. Can the ink not be getting to the printer head?
Unplug the printer for at least overnight. I have 3 of these printers and all 3 have done this. All 3 came back after being unplugged for a long period.
Personally, I think a class action suit might be in order.
Nov 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Canon pixma mp530 not printing colour. The cartridges are new, when I print an alignment, no colour prints, only the black and white. I've performed a clean, deep clean, print head alignment, nozzle...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I have not been using the Brother MFC 465CN printer for a while. Bought and installed new cartridges, cleaned the print head several times (from the printer menu option). But, nothing is getting printed....
May 24, 2011 | Brother MFC-465CN InkJet Printer
All the pages I print are blank. There is sufficient ink the print preview shows the image but the actual print out is blank
Sounds like your print heads are clogged. This is quite common. Go into your printer's menu and find the maintenance menu and follow the steps to clean your print heads. Run the process everal times until the prints are 100%. Then run a printhead alignment. Regardless of whether your not your ink is full, if cleaning the heads several times does not solve the issue, put new ink cartridges in because you may have bad cartridges. If that doesn't work, you've got bigger issues, contact the manufacturer.
Apr 26, 2011 | Office Equipment & Supplies
No Printed documents
Have you performed a print head cleaning? If not, follow the instructions below:
1) Press <Menu> on the panel repeatedly until [Maintenance] appears on the display
2) Press left or right arrow buttons until the cleaning setting you want appears, either [Head Cleaning] or [Head Refreshing]
3) Press the <OK> button.
Note: Head cleaning should be attempted first, and may need to be done more than once. Examine the results of the test page.
Head refreshing is more aggressive, uses more ink and should only be performed when necessary (ie. when multiple head cleanings failed to solve your print problem).
Dec 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printed pages come out with dark lines under each line of print
Find your printer's "Maintenance" menu, in its "Toolbox" or from the Start Menu.
Preform a cartridge or head cleaning, that should solve your issue. If not, try replacing the cartridges with new ones.
Hope I helped,
Tom
Jun 21, 2009 | HP Photosmart C5280 Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
63 people viewed this question
old marine
old marine
