Question about Lenovo ThinkPad T61 Notebook
Fan error is comeing???
I have a lenovo R61.... when i start my laptop fan error is comeing..... i cleanup my fan 4m in side also... bt it doesnt work....plZZzzzz help me out ...
  • gcsltd
    gcsltd May 11, 2010
    what's the cpu temperature?
  • 73 Answers
Actually u need to get it checked at service centre it is not working properly. may be it can get repaired or else u need to replace the fan
Posted on Feb 05, 2010
  • Vineet Pushkar Feb 05, 2010
    actually u need to get it checked at service centre it is not working properly. may be it can get repaired or else u need to replace the fan
Lenovo r61 startup repair is not working
What were you doing before it happened?
Apr 15, 2014 | Lenovo ThinkPad R61 Notebook
Lenovo r61 screen
Open the panel on the back and remove the ram. Boot the computer. If the boot code changes then it's probably bad ram. If it's the samew beep code then probably a bad motherboard
Jan 20, 2014 | Lenovo Computers & Internet
Automatic air blowing
Not necessarily. Try blowing out with canned air.
May 29, 2013 | Lenovo ThinkPad R61 Notebook
Remove dent
IBM/Lenovo ThinkPad R61 Notebook PC >
Bottom Case Cover, (Base Enclosure),
http://www.ebay.com/itm/NEW-IBM-45N4073-Lenovo-Thinkpad-R61-15-4-Bottom-Case-Base-Cover-42W2231-/360642073440?pt=US_Laptop_Housings_Touchpads&hash=item53f7f15360
Keyboard/Palm Rest Cover Bezel,
http://www.ebay.com/itm/IBM-ThinkPad-T61-T61P-R61-14-1-upper-keyboard-palmrest-bezel-cover-42W2466-/400491727269?pt=LH_DefaultDomain_0&hash=item5d3f2ac9a5
Palm Rest Cover,
http://www.ebay.com/itm/Palmrest-Assembly-Cover-IBM-Lenovo-ThinkPad-R61-R61i-14-1-Laptop-/281030800308
Not advertising for seller nor website. Just examples.
Here is the free HMM from Lenovo Support.
It is the Hardware Maintenance Manual. The Service Manual.
Shows and details how to replace the above parts,
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-67760
Also USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Here is an average example,
http://www.radioshack.com/product/index.jsp?productId=2103245
For additional questions please post in a Comment.
Or click on Reply at end of solution, and post.
Regards,
joecoolvette
May 19, 2013 | IBM Lenovo ThinkPad R61 Notebook
Horizontal lines in lenovo r61
This is a indicator of defective LCD screen, the only option is replace the laptop monitor, go to www.ebay.com Type make and model of laptop, refine search to screen to get an idea of pricing.
Jul 03, 2012 | Lenovo ThinkPad R61 PC Notebook
I hv lenovo thinkpad r61.. i hv drivers bt,itss nt
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
Dec 02, 2010 | Lenovo ThinkPad T61 Notebook
When i am starting my lenovo R61 which has vista installed, it is not starting at all. The AC power light and the battery lights get on along with wireless light. The other two lights will on and off after...
Drain Flee power
Steps
Disconnect AC adapter,
Remove Battery
Press and hold power button for 30 seconds.
Reconnect adapter and battery
Start your pc and go to safe mode and check power settings.
Depending on your OS check event log /windows error log to find out what is causing the problem. And disable the service or reinstall driver needed.
Aug 10, 2010 | Lenovo ThinkPad R61 Notebook
Lenovo ThinkPad R61 Fan
Were you able to fix it? I took out the fan and cleaned it with a toothbrush (didn't disassemble it). If it worked, can you provide some insight into what you did?
Feb 27, 2010 | Lenovo ThinkPad R61e Notebook
I have lenovo R61 T7100 every time i insert a
which is the operating system you are using
Jun 09, 2009 | Lenovo R61 T7300 Notebook
Lenovo R61 won't get to login
I,d suggest To charge the battery Fully.
Then power up the laptop, with A/C Adaptor connected.
Also check your models user manual, regarding the sleep/hibernate mode. the laptop may have gone into one of these modes. Usually a ( zzz ) Icon Key or Similar.
Also when booting press the LCD/VGA Button.
If all else fails, try to see if your laptop, has a hard-reset button or switch. ** Sometimes this can be a small hole ** On the underside of laptop. *** Only use with laptop Powered Off ***
Mike @ Compurepair.
Jul 03, 2008 | Lenovo R61 T7300 Notebook
Lenovo ThinkPad T61 Notebook Logo
1,100 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
