Question about Motorola Mobility I335 Cellular Phone
Screen wont display but phone works what can I do.
I have a iphone 5 which is under warranty but the screen is broke the phone was still working fine until recently it now wont stay on will apple repair why it wont stay on under the warranty
Generally, a broken - as in one or several cracks in the glass front - won't cause the phone to fail to turn on, unless water or other liquids have gotten into the works.
You could take it in to the Apple repair place with the broken screen and ask them to check the battery first as that could be the problem. If they say the screen is the problem you could decide then what to do. Those screens aren't too expensive but the labor to remove the old one and install the new one amounts to a couple of hours. The phone has to be just about completely dismantled to replace the display. I replaced the display an an iPhone 4 and it tool me three hours work. The display/digitalizer only cost 16 dollars. The replaced display's glass was terribly cracked and crazed but it continued to work and it never affected battery life.
Mar 08, 2015 | Apple Cell Phones
Fix touch screen phone
what type of phone is it? it sounds like your digitizer has either come loose or stopped working. I specialise with iPhones but on most displays youll have your LCD (picture) and your digitizer (touch screen) actualy attached to the screen is 2 ribbons which connect it to the motherboard in the phone. Your digitizer could be gone and hence why your touch screen wont work. either that or its came loose somehow.
Jul 04, 2013 | Cell Phones
Wont turn on just blank screen
Hi,blank screen display are usually caused by, flex or a damaged screen.
The flex is can be found inside the phone and it enable screen display.
Secondly,when you test for flex,also check the screen.to be sure is not from the screen.
Take care.
Aug 07, 2010 | Panasonic X700 Cellular Phone
I droped it and the screen wont turn on
Since you said the phone drop from you, it is possible that the screws that attach the screen of your phone is not tight anymore.
I suggest you get a torx6 screw driver, power off the phone, remove the battery and turn the the phone over.
Carefully remove the front cover of your phone that leads you to your phone screen.
Use the torx6 screw driver to tighten all the screws of your screen very well to the panel of of your phone.
Recouple your phone back, put the battery and power on, the screen should display.
But if the screen did not display, it means the flex on your phone is bad and will need to be replaced.,
So change the flex if tightening of the screen did not work, so change the flex on your phone and your phone will display.
Take care.
May 08, 2010 | Sony Ericsson T715 Cell Phone
Bb 9530 work well but screen does'nt work i have change the new screen but the problem still persist i have install os 4.7.0.148 the problem with my screen is black
If the problem persist even after changing the display then issue may be with the strip(which connects the display screen and the board).
Regards, Kesav
Mar 01, 2010 | RIM BlackBerry Storm 9530 Smartphone
Inner screen wont work. i have changed flex cable. its the k1
If the main screen isn't working but the outside (CLI) screen is, then the problem is almost certianly that the actual LCD has failed - although it is worth reseating the flex cable from the LCD screen to the display board just in case.
Oct 08, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
My screen wont turn on but the hard keys stay on
especial settings - star, right, star, left, left,star, left star.Then select service tests and main display.If nothing happens then your phone screen is nakered(These setting MAY not work because i have a sony ericsson but has worked on other phone and has not worked on other phones)Hope this helps. :-)
May 28, 2009 | RIM BlackBerry Storm 9530 Smartphone
Sony p1i display screen problem or software problem??
sorry to say the display ic might have knocked off. if soft ware problem u wont might be able to make and receive calls either
Oct 29, 2008 | Sony Ericsson P1i
Blackberry 8100 screen wont work
check your display! i think display is problem in your mobile! IC fault in display!
Jul 10, 2008 | RIM BlackBerry Pearl 8100
My screen wont work!! :s
hav u dropped ur h.set ?if yes contact lg  care center. if not then take the back up of data & reset ur h.set .check display settings & try to set some theme.
Oct 21, 2007 | LG Shine KE970 Cellular Phone
Motorola Mobility I335 Cellular Phone Logo
13 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
