Question about Vacuums
The circuit breaker on the unit pops almost every time I use the unit, what might be causing this?
  • joew930 Feb 05, 2010
    THe unit has been replace once for the same reason.
    President:
  • 1,515 Answers
Hi, when the breaker trips every time you turn it on, the unit has a dead short. It may have a frayed wire where it goes into the units motor, or the motor it self may be shorted out.A bare hot wire that touches metal will pop the breaker right away. I would look the cord over very well to see if anything may be bare. If not, the problem is further into the motor section of the unit, and more then likely the motor has failed. This is why the breaker is there for this reason. In case it overloads or you have a short, it trips to keep the unit from burning. Please keep me posted.
Sincerely,
Shastalaker7
Posted on Feb 05, 2010
  • Robert Horton
    Robert Horton Feb 06, 2010
    Hi, even if it has been replaced for whatever reason, you have a short in the unit, where has to be determined. If you are inclined to check the wiring to the unit, you may find the short.What ever was replaced before, the breaker, Or what, needs to be looked at again as it has happened again. You can start disconnecting electrical parts to the unit one at a time until the unit quits tripping the breaker and you will find out what is faulty. If you are saying it was the breaker that failed the 1st time, it could be the breaker again, as they do wear out. Let me know what was replaced and we can go from there.
    Shastalaker7
Rainbow pn-2e circuit breaker
The circuit breaker could be defective.
Aug 19, 2016 | Rainbow E series Canister Wet/Dry Vacuum
I have a 4 yr old vx6000c central vac that constantly blows house breaker
This unit requires a 15AMP 120 VOLT dedicated circuit. If there are other appliances or items on this central vacuum circuit, this could overload the circuit causing it to pop. The other issue that could be occurring is that the central vacuum is on a GFI circuit or ARC fault circuit. Central Vacuum Units are not designed to run on these types of electrical circuits.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
Jun 06, 2014 | Broan-NuTone Vacuums
Kenmore canister - trips 15 amp circuit breaker
Check specs on unit and amperage. If it is less than 15 then the upstairs breaker is kicking off prematurely - Not uncommon event. If unit is drawing more power than specs there is excessive friction in motor bearings. Also check out brushes for good contact since they wear.
Sep 11, 2017 | Kenmore 25512/ 25513 Progressive Canister...
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
My e wave microwave appears to be in fine working order until the door is opened. It then trips the breaker and ceases working. Ater the house breaker is reset, the power is restored to the microwave...
You may have a short circuit on the INTERIOR LIGHT BULB circuit in your microwave.
This might explain why the breaker trips every time you open the door.
If so, you would have to unplug and disassemble the unit in order to access the wires and light bulb socket inside the case in order to troubleshoot and repair the problem.
If you are unfamiliar with safe electrical troubleshooting and repair procedures, please be extremely careful or consider hiring an electrician to do the work. There are some hazardous components inside which remain dangerous even after the unit is unplugged.
Good luck.
Apr 19, 2011 | Vacuums
System quit working green light on
depending on the year of your machine, assuming it is the serenity blue, it may be the circuit board on the unit itself. The manual switch "should" start the machine, but if not it will be the circuit board inside the main unit.
however....
if your unit is the green one, it may be the motor inside the unit and/or the circuit board. Hard to say. I do not think that it is the motor as the circuit breaker should have popped out if it was the motor.
Regardless of the colour of the unit, if it is 5-7 years old or less, the unit should still be under warranty. home service calls and labour to install the motor would not be covered.
Good luck.
Nov 19, 2010 | Beam Industries 2775 Serenity Plus Central...
My Hoover Windtunnel blew the circuit breaker today, and did so again after I reset the breaker and turned off the only other appliance on that circuit. Any advice? Thanks from GrGrandma in Fremont
There could be a problem with the vac, the only way to know is to use an ammeter and test the current draw of the unit. If the vac is ok, the breaker could be failing. Plug the vac into another receptacle on a different breaker and see if it still trips the breaker; if it does, then have the vac checked out
Aug 18, 2009 | Vacuums
Unit will not turn on
Unplug the vacuum unit from the wall. If it is hard wired turn off the circuit breaker
Jul 30, 2008 | Broan-NuTone CV450 Central Bagged Central...
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Vacuums Logo
133 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
