Question about Akai PDP-4216M 42 in. Plasma Television
Plasma has lines/bars.
Tv was fine when I turned it off this morning, I got home this afternoon and it now has verticle lines or bars in many different colors that seem to move from left to right. This unit does not have a tuner it is just a monitor, I have tried hooking it up to different sources, this didnt make a difference..
Also, when I hit the menu button the screen will go black and show only the line in the area where the little menu box would pop up..
Any help is appreciated..
  • cjohnson03 Feb 26, 2008
    Getting multimeter from work tomorrow..
    I will take the readings and post accordingly.
    If there were any bad fuses would the tv still come on?
    Also, I dont know if this helps, but there are some red and green lights on a couple of the boards, one of the green ones flashes all the time and it has 2 green lights next to it that burn steady.
  • 4,889 Answers
Looks like its a problem with the capacitors on the power supply zone.. DO you have experience in electronics? If yes just get a multimeter and check for any open circuits by measuring the voltages. Also check for blown fuses.. If you cant figure out whats wrong..get me the multimeter readings so that we can fix it..
Posted on Feb 21, 2008
  • eagle338
    eagle338 Feb 26, 2008
    ok.. the black part is only where the menu box shows up? Then its not a problem in the power supply.. Its probably just a few dry solders or loose contacts... When the lines are showing up just whack the the tv a little bit.. If you see those line patterns change then its a very easy repair job and should not cost you much at all.. let me know what happened..
    Genius:
  • 3,422 Answers
The first thing i would say is check your cable box.Try adjusting he wires attached to it properly and then see if it makes any difference.iF it does then the problem is with the cable box you have to call you cable operator to fix this.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Do a hard reset (just to make sure there is nothing in the coding that is fowling things up). Unplug the power cord; leave it disconnected for 4 hours. That will restore everything to factory defaults when you power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic places to see if there are any cold solder joints or loose wires acting up inside the set.
The display driver board has probably got a bad connection, loose solder joint or bad IC.
If the above steps don't solve ur problem then I suggest you to go for a repair.Th cost will be around $300.
Goodluck..
  • 2,335 Answers
Very often when the power supply is not giving you pure DC due to defective capacitors. This seems to be a common failure on LCD and Plasmas power supplies.
This failure may also be around the vertical section of this TV.
I would suggest to take it to a repair shop or if the TV is still under warranty call the place where you bought the TV and ask them for an authorized repair centre.
    Brigadier General:
  • 3,614 Answers
Hi sir,
Samsung Plasma HP4252 type SR42P5 verticle blue lines across entire screen
First off there isn't a timing board in a plasma TV. I would guess you have a bad y-sus board.
Feb 20, 2018 | Samsung HP-R4252 42 in. Plasma HDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Colored verticle bars, some w/colored snow,picture is still on
It sounds to me like you have a bad plasma panel. Unfortunately you may now be in the market for a new TV if you are not under a warranty of some kind. That issue is unfortunately unrepairable because it requires you to replace the entire panel and therefore is not cost effective.
Jan 23, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Green TV with lines through it
require model number of unit and how often this happends
Jul 16, 2008 | Samsung DLP HL-P5663W 56" TV
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Verticle Bars down each side of screen
It would be in video settings mode if avail. Being a plasma it might not be available,this feature is to prevent burn in.
Mar 21, 2007 | LG 50PX4DR 50 in. Plasma TV
Akai PDP-4216M 42 in. Plasma Television Logo
102 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
