Question about Acer Aspire 4720 Notebook
My Acer laptop has a faulty graphics chip that distorts the display, causing lots of squares to appear in rows on the screen
  • Acer Master
  • 2,517 Answers
Dear Friend i understand the problem. Please follow the steps here under.
1. Uninstall the display driver from device manager then, restart & again install it from
Acer Driver cd.
2. Right click on desktop then select properties.
3. Click Settings. The fix screen resolution 1280 by 800 and color
quality high.( 32 bit).
4. Now press apply & ok.
Hope its helpful for you.
Thanks.
Posted on Feb 05, 2010
Try Best buy. They helped me.
I have (suddenly) a single dotted black line about a quarter wasy down my screen on laptop. Can I get rid of it?
First, you need to verify if the dot is cause by faulty graphics chip/card or LCD/LED. To do this use external monitor, if you cant see dot on your external monitor then you have faulty LCD/LED if you see dot like in your laptop the you have graphics chip/card problem.
Oct 09, 2014 | Acer Computers & Internet
Pinks squares on Dell laptop screen
Try connecting to an External Monitor via the VGA Port, if Ok on a known good monitor then ONLY the Screen is faulty, if pink squares show up on the external monitor than video chip (Graphics inside the Laptop and on the Motherboard OR cable from motherboard to Screen, see how you go.
May 01, 2013 | Dell Computers & Internet
I have ma Acer Aspire 5610z laptop when i switch on it does'nt display on the screen and am already check all connection of screen its correct so what can i do
Try connecting it to a second monitor to test the screen. If the computer acts like it is starting, but nothing happens, lights are on and screen is dark, the CPU may be broken.
Aug 29, 2011 | Acer Aspire 5610 Notebook
My picture has been pixelated
Probably a bad display driver ( download the latest driver for video chip from the website)
Or might be the resolution is set too low ( right click on desktop / personalise / display settings and change) For XP, its changeable in the control panel / display box.
Test the laptop by connecting it to an external monitor, see if you get the same problem (if you do, see below re: graphics chip, if not, see below re: screen
After that, this could be faulty hardware, overheating graphics chips will cause the display to do this, best solution here, dismantle and clean the heatsink and fan, remove any dust build up.
If that still fails to work, the chip may be damaged beyond repair (new motherboard / graphics board depending on the laptop you have), Or, the screen itself may be failing (replace screen)
Jul 03, 2011 | Computers & Internet
Coloured squares appear on screen
Seems to me that the LCD cables are not properly atached.
Double check all the LCD connections.
Your problem will be solved.
Jul 05, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
On start-up, the first screen with the Microsoft flag logo has a matrix of blue square dots (about 1/8" square in size) superimposed over the entire screen. Then, when the desktop appears, about half of...
go into your bios and make sure that video memory shadowing is dissabled, Sounds like a faulty video card or damaged signal cable. I would lean more to the faulty card though, try installing a new one as I would say thats your issue if your getting artifacts on the screen before the OS has fully loaded.
OFC you could try new drivers both for your chipset of *********** board and the graphics card in the interim.
Jun 22, 2010 | Dell Dimension 4600 PC Desktop
Acer Aspire 5585 Graphics card problem
the chipset is integrated onto the motherboard, to fix the issue would be to replace the motherboard.
May 01, 2010 | Acer Aspire 5500 5570-2609 Laptop
Fan for my acer 3690 spins, green light is on but no display show
Look to See If Your Hard Drive/Data Indicator Light is on and blinking (or solid)..
You need to try and hook up a desktop monitor to the laptops serial port.. Reboot with the External Screen Plugged Into The Laptop.. If You See Windows Booting From The External Monitor - Then You Have A Faulty Screen, or possibly a faulty Display Cable.. Most Likely The Screen Has Failed Though... Also, Hold The Screen Up To A Bright Light while its powered on, You Might have just lost the backlight and have a display still, It will be REAL faint but holding it up to a light and looking to see if you can see Windows Running..
If No Display on the External Monitor When Connected To The Laptop, Then You Have GPU/Graphics Failure, Due To Thermal Damage.. This Is A Motherboard Issue Because The Chips Are Integrated.. A ReBake/ReFlow Of The Chips Will Get Your Video Back, Or Replacing The Motherboard.....
Nov 15, 2009 | Acer Aspire 3690-2196 Notebook
Acer Aspire 9303wsmi No Display on LCD, no display using external VGA DSub, (no sign of characters on dark screen (ie if the backlight had failed) removing all power and battery and using one or other...
One long and two short beeps indicate the problem with the display card on most of the laptops. Graphic card is integrated to the motherboard. Therefore the motherboard needs to be repaired.
Jun 26, 2009 | Computers & Internet
Acer 5670 screen has dark transparent vertical stripe
you will need to check the display cable and if that is ok, you will need to replace the display panel... You're getting a short on the circuit board causing rows of pixels to be blocked out
Here's your display on ebay...
http://cgi.ebay.com/NEW-ACER-ASPIRE-5670-15-4-WXGA-GLOSSY-LCD-SCREEN_W0QQitemZ320249932106QQihZ011QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Jun 13, 2008 | Acer Aspire 5670 Notebook
Acer Aspire 4720 Notebook Logo
126 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
