Question about Dishwashers
Machine washing I need to know like is sistem trasmission drive of motor whit machine in the washing machine MODEL :LLR6144AQO SERIAL .CC1819282
    President:
  • 2,651 Answers
What did you nee to know???? check that model doesnt seem valid, whose the manufactue,
Posted on Feb 22, 2008
WASHER WILL NOT SPIN
could be a couple things first thing to check would be the drive couple if you can hear the motor running this is usually the first thing to go because in the factorys they purposely install this piece as 100 percent plastic and it should only last about 2 years from the factory date its the piece that connects you motor to the trasmission please write back with your model and model numer and check the drive couple first and get back to me please remember to rank how this opinion has helped in your appliance situation and if i can answer any further questions please write me back thanks again
rickead1
Sep 02, 2010 | Roper RAS8445KQ Top Load Washer
Fills with water does not wash on wash cycle makes a sound like the engine is running but no movement, wont wash or spin.
bad drive couple costs about 10 bucks most techs charge between 159-189 to replace takes about 15 minutes to replace it you can order the part from marcone appliance parts and they will mail the part directly to your door first thing to do is remove the cover and check to see that it is the drive couple with the machine unplugged and the cover off feel in the back of the motor in between the motor and the transmission for a rubber disc and try to spin it if the motor spins but the trasmission doenst then u have a bad drive couple hope this helps
Aug 09, 2010 | Kenmore 24032\24036 Top Load Washer
It will wash & ranch but want spin out the water but drain it out.
tip unit back and lean against the wall so you can look under it.
check your drive coupler
take the pump off 2 clips push up on the top one and down on the bottom one.
take your motor down usually 2 clips and 2 screws
now on the other end of the motor you will see an attachment that is your drive coupler it's probably broken.the other side sits on the transmission....is the rubber ok? is the plastic ears ok?
if the answer is yes you may have a bad clutch whisch sits above the transmission.
if you have a bad clutch you are going to have to take the agetator off first..before dropping the trasmission.
First check the drive coupler part number for that is 285753a
May 04, 2010 | Kenmore Washing Machines
My transmission makes noise whit a push when set
sounds like it didnt get put back in correctly
Aug 13, 2009 | 1999 GMC Yukon
Washing machine drum won't turn when loaded
your gers in the cluch sistem are gon for good ,,sorry
Apr 05, 2009 | Fisher and Paykel (IWL12)
Whirlpool mod#LLR6144AQO electrical issue
If you have power at the console where the power cord connector connects to the harness then make sure all wire harness connections to the timer are tight. If so, then something must have happened to the timer as nothing else will keep the machine dead in fill and spin.
Nov 30, 2008 | Whirlpool Washing Machines
Kenmore washing machine
Hi heatherrosco,
If your washing machine will wash but not pump out or spin then you have a bad lid switch. The lid switch can be checked by poking a ink pen down into the hole on the top of the tub while the machine is turned on and in the spin setting. If you poke the switch and it does not spin or pump out the water the switch is bad. If the machine will not wash or spin and will only fill and pump out then you have a bad motor to trasmission coupling. These can be purchased at any appliance repair center for about $15.00 The coupling will go between the motor and the transmission and act as a shock absorber. It is a fairly simple repair for either part, please let me know what you find and I will be happy to tell you how to complete the repair. If you need the parts I can also ship it straight to your door and give you advise over the phone while you install. Good luck on your repair and remember I am here to help. Please dont forget to rate me also.
Mike Anderson ( Owner )
Anderson Appliance Repair
(865)945-3808
Oct 27, 2008 | Kenmore 24032\24036 Top Load Washer
Sistem crash
if you know what motherboard you have find the manual on the internet and you will be able to see exactly waht kind or ram you can get (i'd suggest Kingston)
Oct 16, 2008 | PC Chips M909G Motherboard
Problem whit evap sistem corolla 98
you may need to change the actual charcoal canister that is what turned my check engine light off..
Aug 07, 2008 | 1998 Toyota Corolla
LG WFT7030TP
Trouble shooting a washing machine is easy but you have to know the sistem first if the washine machine take water wwell but dont do nothing eals could be a couple of things. The water level switch send curent to the water selenoids when the maching is empty then when the level of water reach the selected level the presure of the water active a presure swithc and the curent go to the timer there the timer send the curent to the motor, as you can see there are a procedure that you have to know to repair a washin machine and some instrument to trace continuity and curent warning disconect the machine frome ac outlet befor service .....good luck and rate me if you survive this riskey adventure...
Feb 17, 2008 | Washing Machines
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
