Hi i am trying to buy a relacement power adapter lead for Behringer UB1202 Mixer.... i cant seem to get one any where and my local shops have never seen one like it the part that goes into the mixer has little pins inside it to connect and there are 2 broke off...when we bought it 2 years ago it came with an usa power lead and we just bought an adapter to use it and i think that is why we are having problems getting a replacement please and thank you
  • 1,476 Answers
Here are all the specs.
http://www.behringer.de/EN/Products/UB1202.aspx
If you could look them over it tells what kind of adapter you need to power the unit. I would also need to know what kind of power you are plugging into ie 120 vac etc. Look at the sheets and let me know. I will then try to find what you need or perhaps explain how to make what you need.
Hardrocko
Posted on Feb 05, 2010
Where can I find a schematic ?
Try http://elektrotanya.com 2 downloads per day for free, else pass the electronics test to create a login & get more :-) Good Luck!
Jul 31, 2014 | Behringer UB1202 Eurorack UB1202 Mixer (12...
How to connect UB1202 to an Amplifier
Hi ha07. Have you fixed your Problem? If not, If you are using a HiFi amp you can connect it to any AUX input or tape in.
But better to use Aux, so you can keep Tape-In free, but it all depends how you want to use your system for recording
From the Mains "OUT" of your Mixer, 1/4 inch to RCA lead/s or adaptors will be needed, (Depending on your AMP) into the aux input of your stereo. But their is many scenarios for inputs and outs.
then you can run a lead to your computer from your Mixer or amp from Tape out, but again lots of possibilities.
Hope this helps if you haven't fixed your problem
Dont use (Phono input)
RustyRecords
Good luck and Vinyl Rocks RustyRecords Mail
Jun 29, 2012 | Behringer UB1202 Eurorack UB1202 Mixer (12...
On my Behringer UB1202 mixing board none of the inputs work. I plug headphones into the headphone jack to monitor. Neither dynamic nor condenser microphones work (with phantom power enabled when...
Does your computer Recognize the mixer. and to answer your question honestly Behringer is Junk they make cheap knock offs of really expensive products. but see if your computer recognizes it and if not i sugguest taking it back
May 13, 2011 | Behringer XENYX 1202 Premium 12-Input...
Fuse and fuse holder needed for Behringer 3000 pmp mixer
Try this Behringer support:
BEHRINGER USA, Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
Fax: +1 425 673 7647
I just repaired a PMP3000.
A bit of warning on these. Do not let a speaker leads get pulled while powered. They can arc out the power amp causing extensive damage.
If the fuse ever blows do NOT replace the fuse as much more damage will result. Service the unit before using.
May 12, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
I've never used PA systems or vocal setups. My band has been looking for a vocal setup and I came across these products. Mixer~...
Hi, the speakers are unpowered, but that desk is also unpowered, so you need an amplifier in the circuit. This can either be in the desk, in the speaker, or a separate device, there are advantages to each.
Aug 30, 2009 | Behringer Audio Players & Recorders
Power supply cooked
There isn't anything in the power supply you cannot rebuild except the transformer.
BUT you should verify that something in the mixer didn't short out and damage the supply.
After you relace the smoked parts (likely the TOP245Y offline regulator chip is gonzo... then you use this trick to restart the unit safely:
Put a 60 Watt light bulb in series with the hot side of the input power line. I would recommend you use an ISOLATION transformer when working on the power line side of this for safety.
Jan 17, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
AC POWER PACK BLOWN
David,   I dont like to be the bearer of bad news, but Behringer dissolved its service/repair center years ago.  In my opinion, this indicates little faith in the profitability of servicing Behringer products.  If the manufacturer wont even repair their own products, I wouldn't buy or use that brand if I had a choice.  Their products are good, WHEN THEY WORK.  They keep their prices low by using inexpensive, disposable quality components.  Most of their products aren't worth repairing.      Here are a few options to find your power supply.  Try Rogue music in New York, NY.  Here is the web address.
www.roguemusic.com
Here is another resource.  DBM pro Audio is an authorized Behringer Repair Center.  They are also in New York.  They will be able to tell you if your part is available from Behringer.  I'm very sorry to inform you of the inferiority of Behringer products.  I think the truth, though it hurts sometimes, is the best teacher.  P.S. if you ever visit DBM... next to the elevator, outside DBM's office is a one yard dumpster, it is always brimming with the carcasses of unrepairable Behringer mixing consoles.      Remember, when buying electronics, you get what you pay for...cheap price = cheap components (and usually headaches down the line) Good luck!  I wish you success on finding your power supply.  Michael Mittelsdorf
www.dbmproaudio.com
See my profile for my qualifications. DBM does all my electronics repair.
Jan 09, 2009 | Behringer Rx 1202fx 12 Channel Line and...
173 people viewed this question
 Grubhead
Grubhead
