Question about Lanier 5222/27 Laser Printer
Misfed jams I keep getting message " clear misfed jams" even though nothing is there to be cleared. please help
  • 2 more comments
  • samle16 Feb 23, 2008
    it is from A.
    Is this the page we are comunicating on this suject? if not, please tell me where to go.
    i posted your request hours ago, but no one gets back to me. please help me
  • Dale Richards
    Dale Richards May 11, 2010
    Where does it say it is jammed? A,B,C? Does it do it from all trays?
  • 87 Answers
First off, does the wheel indicate the proper size paper. Be sure to place close attention to the icon. Second, when you slide the drawer out, in the middle of the right edge, there is a spring loaded pad. Carefully peel the cork off, and rotate it 180 degrees, or you could switch it with the other drawer. Other than that, there might be a small wedge of paper in the lower switch, located in the middle of the paper path, between the paper guides. It may be next to impossible to see unless it is taken apart.
Posted on Feb 24, 2008
  • Dale Richards
    Dale Richards Feb 24, 2008
    One more thing, I want you to get the error code for me.
    Press Clear Modes, 1. 0. 7. and press and hold clear/stop. It will beep. and select 1 for copy sp. press next untill you get to 7/data log. Press ok. key in 7910, and press ok. Send me the info from that code. Exit all the way out and recycle power.
Paper jam error message
On mine you have to take the duplexer out of the back of the machine to convince it there's no jam. On the 4350 you press 2 buttons on the sides of the duplexer and it slides out. Look at it, scratch your head and then push it back in. Magically the paper jam is cleared.
Apr 05, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
I had a paperjam and even after clearing the jam, it's still telling me that i need to clear it. I know there is nothing in there and have tried everything i know to do to clear out this message. Does...
1) try to unplug power cord
2) check sensor flapper in fixing assy
3) open close few times all doors
4) if that helped clean rollers pick up, feed, separation
5) if nothing helps call service because you have pcb error issues
6) if you do not want to call service - Throw it trough the window :-)
Hope that helped.
Jul 02, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Paper jam error message..no jam
Hello There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Panasonic Workio DP-2000 j33 problem
The sensor arm just below the registration roller has dropped the spring to return it to it's home position.
Mar 27, 2009 | Panasonic Workio DP-2000P Copier
Keeps showing "document jam" even though the jam was cleared
Most likely one of the jam sensors was knocked out of its clip. You would have to take the document feeder off and apart to find and reseat it.
Mar 25, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Print factory 2 Paper/CD jam fault
My e-mail is jounikontulainen@gmail.com.I could mail You technical document that might help.
Jouni
Apr 05, 2008 | MicroBoards PF-2 InkJet Printer
207 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
