Question about Gateway NX860X Notebook
System recovery on gateway laptop now no internet
Just did system recovery cd on gateway laptop now no internet/wireless network avail.
    President:
  • 1,146 Answers
Hi:
If you are on your own home network, you might need to set your connection back up, especially if your network was secure.
If you don't think that is the problem, the other possibility is that your laptop needs drivers installed after the restoration process. If you go to the control panel, and check system info, then device manager, if anything has a yellow exclaimation point or question mark by it,the driver needs installed.
If you don't have a driver or program disk for your laptop, they can be downloaded from the gateway website.
Posted on Feb 05, 2010
    Guru:
  • 239 Answers
Do u have a switch enabling/disabling wifi?
if yes, turn wifi on!
I have a windows 8 gateway laptop(NE71B Series) and its seems as if my wifi switch is disable. Anyone with a bit of advice on how to resolve this problem would be very helpful.
Recently had a coworker bring me a Gateway NE71B laptop.
Complaint: No wireless even using a VZW 4GLTE hotspot.
Observations:
; All drivers and devices are functional with no errors or conflicts.
; Wireless adapter has power and is not in Airplane mode.
; No wireless networks are visible even though there are normally as many as 12 networks available within the area.
; Wired Ethernet adapter works without issues.
Solution:
Turns out the BIOS was v2.05. After updating the BIOS to v2.13, wireless connectivity is functional. All locally available wireless networks (SSIDs) are visible.
Notes of caution:
; A failed BIOS update will invalidate your warranty per Gateway chat support rep.
; Ensure you have a fully charged battery before updating the BIOS.
; Ensure your AC adapter is plugged in and functional prior to starting the BIOS updater.
Jan 22, 2013 | Computers & Internet
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
I have a laptop computer, and a wirless no internet
your internet gateway (the modem)if you have att you must turn on the the wireless inside your 17XXhg gateway modem if you don't then you have another system I gave you a example to clear your question if you need more help please repost with more information
Jan 14, 2010 | Computers & Internet
I have a Gateway T-series (Model:W350A) laptop. I just reinstalled Windows Vista and now the computer is not recognizing the built in wireless card. How do I get it to recognize it? Or how do I install the...
Plug in an ethernet cable into your ethernet card port on the left hand side of your laptop. When it connects to the internet click on the Windows update icon in the system tray. It should show you a Realtek Wireless RTL8187b wireless adapter driver update. Install it, you may need to reboot, but in any case you will have wireless networks available to you and you can pull out the ethernet cable. Good luck.
Dec 30, 2009 | Gateway M305CRV Notebook
I have had to rebuild my Fujitsu Amilo Pro V2055 from scratch. I cannot get onto the internet even when wireless button is showing ready. I cannot get to the screen that tells me what the available...
Did you reinstall all drivers from the recovery CD? Windows should have detected the wireless card and installed the software for it and notify you automatically of nearby networks without any further software being installed.
Aug 31, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Ethernet port on laptob gateway not working
http://support.gateway.com/support/drivers/search.asp?param=MX6447&st=kw
From a computer that has internet access, download the appropriate ethernet driver for your network card from the link above. As for the recovery disk, you'll have to contact Gateway for a replacement disk.
Apr 14, 2009 | Gateway MT3705 Notebook
Not able to go online
If you have access to another computer you can go to the gateway site, download and burn the programs you need on cd or flash drive. Then install the flashdrive or cd into the laptop. To find out what programs you need to install on the gateway, go to the control panel>administrative tools>computer management>device manager.
Nov 06, 2008 | Gateway 7330GZ Notebook
Wireless connection
Access the routers admin page with the hardwired pc.  http://*gateway*  right click network status on pc and get gateway.  Google the model you have for the default passwords.  Setup your wifi security then do the same to your laptop and attempt to connect again.  Bad settings somewhere.
James Mac
Sep 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Gateway mx3560 wireless (yellow exclamation mark) on device manager
Obtain an ethernet cable and connect to the Gateway Support site using wired network temporarily to download and install the proper wireless driver.
May 29, 2008 | Gateway MX3560 Notebook
Hello
sir all the toshiba laptop driver is available in the internet... just rent in a cafe shop and download all that you need from he toshiba website... then if possible just burn your copy in a CD or just put it in a portable storage...
hope it helps
Jan 19, 2008 | Computers & Internet
Gateway NX860X Notebook Logo
124 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
