Minolta CF900 error C0660 / scanner motor
I was told by a tech to reset the copier by turning on and off. That did not work. there is no power going to the scnner section at all. Matter of fact it copier turns on but nothing I mean nothing is working other than the LCD screen. None of the fans are running at all. Is this a bad motor or a bad power supply?
  • 2 more comments
  • wildfire08 Feb 21, 2008
    I get the error message C0660. The service log for the copier 6 thousand copies ago states that the tech reset the same error message. this is an old copier but only has 30 thousand copies, could the motor be really bad? Where is this located how do I check it?
    Minolta CF900 Color copier
    when is the original sensor? How do I fix it?
    where is the original sensor? How do I fix it? Still waiting
    Brigadier General:
  • 3,614 Answers
It possibly you've got bad motor, it does'nt respond when you turned on the unit.
Posted on Feb 21, 2008
  • 2 more comments
  • micromaster
    micromaster Feb 21, 2008
    Can you please give the details of your copier (the model and the brand name)
    thanks
  • micromaster
    the error code means thr problem is in original sensor.
  • micromaster
    Kindly wait Sir.
    Thank you
  • micromaster
    Kindly wait Sir.
    Thank you
EP2030 Minolta error code C0660
Under the big glass to your right under that black cover is a lens assy., and mirror assy., something is jammed in there or bad motor. open front door upper left access cover remove cover touch trouble reset to reset machine.
May 08, 2012 | Konica Minolta EP2030 Fuser Thermofuse
I have a minolta 4050 that is showing a 601 error code
SC 601 = SCP board PWB J malfunction or scanner motor malfunction.Scanner motor located in rear parts right side and the PWB J panel in the right side of copier.Try open and closed the front door,push the trouble reset switch,if the error code persisit change the scanner motor or PWBJ.Move the scanner manually,turn ON the power switch,if the scanner exposure lamp move,working the scanner motor is OK.Check the scanner home position sensor.
Oct 30, 2011 | Minolta EP4000/5000 CS/PRO Copier
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Aug 07, 2009 | Minolta Di3510f Bizhub Copier
What does error code c0660 relate to on the Minolta CF1501
Hello sir; Turn power off, remove the glass, push scaner unit for and back see have anything stock over there, otherwise you have to change home position senser.
Mar 08, 2009 | Konica Minolta DiALTA CF910 Copier
Minolta CF900 code C3250
CAUSE: Worn mylar.
SOLUTION: Refer to bulletin 3135 which pertains to the transfer drum joint Mylar.
If you can find a Konica Minolta dealership that can get the part or have tech come out and look at it A VETERAN (NOT MILITARY)Tech you have legacy Minolta now Konica Minolta, CF was first generation color. The mylar is dealing with the Transfer drum the big clear drum next to the drum.
Oct 20, 2008 | Minolta Office Equipment & Supplies
ERROR CODE C0660
This is a scanner problem, try the following...
C0650, C0660
Step Check Item Result Action
1 Scanner can be moved manually.
NO Correct drive coupling (Scanner
Belt tension, pulley operation,
drive cable tension)
2 Scan motion: initial scan motion after the
Power Switch has been turned ON or Front
Door has been opened and closed.
NO Carry out misfeed/malfunction
troubleshooting procedures.
3 Connectors are connected properly on
Scanner Motor Drive Board: PWB-IC
PJ1IC, PJ2IC, and PJ3IC.
NO Check connectors for connection.
4 Scanner Motor turns when the Start key is
pressed.
Change motor. Change
Scanner Motor Drive Board.
5 I/O check for Scanner Home Sensor: the
voltage across PJ6C-2 on Image Processing
Board and GND is DC 0 V (home position)
when the sensor is blocked and DC 5
V when the sensor is unblocked.
YES Change Image Processing
Board.
NO Check sensor for installation.
Correct detecting plate.
Check sensor connector for
connection. Change sensor.
6 “IR Area” check:
Malfunction when Power Switch is turned
ON after “Top Image” has been set to 0 and
“FD-Mag.” to 1.000.
Apr 03, 2008 | Minolta CF2001 Copier
There should be a lamp regulator PCB check the fuse on it. Also, if you move the scanner out of HP will it find HP again? Also, how offten does it show up scines the last time?
Feb 20, 2008 | Office Equipment & Supplies
Minolta CF900 error code C0030
The C0030 is referenced to the developer drive motor for the 4 developer units.
you may need to replace parts.
BUT check the oporation of the unit FIRST. LOOK BINDING IN THE DRIVE UNIT
HOPE THAT HELP
Feb 15, 2008 | Minolta EP1031/1031F CS/PRO Copier
this is not a ricoh,, re code this issue as minolta nd you will get a ready answer...it is in the back of he usermanual
Nov 29, 2007 | Ricoh 6513 Copier
Minolta CF900 Photocopier
CODE C0900, DOES NOT PASS COPY, FIERY FRONT COVER BROKEN OFF AND VERY DIRTY, also you may want to try and look at the 3rd drawer lift perheps there's somthing blocking it
Aug 29, 2007 | Konica Minolta DiALTA CF910 Copier
164 people viewed this question
jasbo
jasbo
