Question about Paini Spa Rubinetterie LaToscana Complete Kit For Shower Panel
I cannot turn the knob that regulates the temperature of the water to the left(which would make the water cooler)after the water has been running hot. We have an ASSE 1016T model.
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
I can't seem to adjust the temperature once I've turned the shower on. Once it gets hot, I can't get it cooler.
is the cold water on! if yes you probably have to remove the cold water knob and stem, to investagate it. the rubber on bottom of the stem may have fallen off and blocking cold water flow. Just check it out !
Sep 07, 2011 | Graff Home
I have an Darlac Electronic water timer DW253 but haver mislaid the instructions, where can I download a set?
I cannot find a manual for the Darlac DW253.
It appears the timer is set by moving each selector knob.
http://www.watermate.co.uk/secure/uploads/DW253%20(Small)%20new%20darlac%20pop.jpg
Knob on right is Run Time:
This is how many minutes timer will run each time.
Set run time from 1 minute to 120 minutes.
Knob on right also has ON-OFF override.
Knob on left is Frequency:
This is how frequently the timer will turn ON. Once per hour, once per each 2 hours ... once per 24 hours ... once per 72 hour ... once per week.
So set frequency to 48 and set run time to 20, then every 48 hours the water will turn on for 20 minutes.
To turn timer off, move right knob to OFF.
For continuous watering, turn same knob to ON.
This timer is battery-powered, probably 9 Volt, but maybe AA.
Battery carriage appears to be located on front below the function knobs.
Typically, water timer batteries last one season.
Timer can be connected to household spigot, or connected to any passive water supply for example rain barrel or tank.
Appears to have standard female hose thread on top, or possibly 1/2 pipe thread, and quick connection on bottom.
Plastic water timer exposed to freezing temperatures can crack. Drain water out of timer during cold weather.
Generally if water timer stops working: replace battery, clean battery terminals, and if functionality is not restored, then buy another timer.
Add a comment to fill out the missing details.
Aug 02, 2011 | Woods Inwall 24 Hour Programmable Timer
How to set temperature
You set the temperature by turning the round knob on the silver box near the bottom front...CW should be hotter and CCW should be cooler...but different ones may vary...
heatman101
Feb 25, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
My oven is at least 15 degrees cooler than it should be. Since I have a digital stove, does that mean it cannot be repaired?
Try this
Turn oven temperature knob to OFF.
2. Press and hold both arrow pads for approximately 5 seconds.
3. A double digit will display ranging from -35 °F to 35 °F.
4. Immediately, press either:
• to increase oven temperature by 5 °F
• to decrease oven temperature by 5 °F
• When temperature is adjusted to a cooler setting, a minus sign (-) will
display with the offset temperature.
5. When desired temperature change is displayed, release control and
change will be automatically saved after a few seconds. Control will
return to time of day display.
• Offset temperature change will be retained through a power failure.
The complete manual can be downloaded at www.appliancehelponline.com just enter your model # and the manual will be on the left hand side.
Nov 05, 2010 | Amana ACF4215 Electric Kitchen Range
Can driving my buick without the thermostat hurt
Yes it can. The car will not get up to operating temperature as fast. It's never good to modify a car from its original factory specifications.
Jul 31, 2010 | 1992 Buick Century
The Marvel 68AR Serial 06090-5018 does not regulate the temputure. When it is turned on it gets as cold as it can and freezes everything.
It sounds as if the thermsitor (temperature dependent resistor used to detect temperature) has failed. You can order a replacement direct from the factory 800-223-3900. PN 42244531 - It used to come with instructions. If you need further assistance, drop me a line. - Subdriver
PS There is one other cause that can lead to similar symptoms: if the unit has a freon leak is is low on charge, it will develope heavy frost on the left wing of the evaporator plate and none on the right and will run almost continously when turned on. This is due to the control senses the plate temperature and not the air temperature. If the frost pattern covers all (or most) of the evaporator plate when running, then my original diagnosis stands.
Mar 16, 2010 | Marvel 6BAR-BD Beverage Cooler
After pugging in the water cooler, the fan starts running, all good water is cold but the fan never turns off. is this normal.
Yes except if it has a temperature control but would cut off only when it has reached the desired temperature, and water coolers are not the efficiency compared to a heat pump or air-conditioning, it only cools the air with the water running over the pads so whatever the temperature of the water is that’s the temperature the cooler will cool the air to. so in theroy it will only drop the temprature 10 to 15 degrees.
Sep 14, 2009 | Hamilton Beach Water Cooler with Storage...
Wine Cooler Temperture Regulation
Replace the circuit board . Please Rate This !!!! Thank You!!
Jun 08, 2008 | Haier HVF042 Wine Cooler
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Paini Spa Rubinetterie LaToscana Complete Kit For Shower Panel Logo
247 people viewed this question
Top Paini Spa Rubinetterie Home Experts
Donni Steen
Tom Chichester
Are you a Paini Spa Rubinetterie Home Expert? Answer questions, earn points and help others
