Question about HP OfficeJet Pro 1170c InkJet Printer
Copier not working in color
When copping in color the first 3 inches is in different shades of brightness. The last part of the printed page is all one drab slightly gray scale. etc a white background is now gray three inches from top to the bottom of the page. As if the lamp is in dimmer mode
  • 1 more comment
  • frank mohr Feb 21, 2008
    not the ink, the scaning is the problem, even when viewing image on the computer. has the various shading issue. printing is not the isue. printing works great. if the image comes from the computer, ex. a web sight print screen
    copy in color gives varring shades, copy in black and white has no noticeable problems. that is copy direct to paper or copy to save in computer same results
    this can be used as a stand alone copier, needs no software or computer atached, to copy. somthing in the color recognition in the scaner?
    Genius:
  • 3,587 Answers
Sounds like a jobg for copier man.
at any rate, you'll find that most likely your cartridges are leaning towards empty, check em first.
Posted on Feb 21, 2008
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Feb 21, 2008
    ahhh..that's different...so, you're copying and scanning are off..you may need to re install the entire printer manager software, since that's what makes this the case..what happens when you do a simple copy to paper in color?
  • Patrick Michaels
    ok..so the printer/copier software, seems to be having some problems interpreting color...hmmm...if the black is good(black being all colors) then there's something else afoot.
    delete the printer and software, and re install fresh from online drivers/software..
  • Patrick Michaels
    yes that makes sense...and the color sensors are intrinsic to the design...
How to remove gray shadings in the background of my printouts for my printer hp color laserjet 5550?
Grey shading likely due to either bad black cartridge. Try a different cartridge first thing. After that, print a PQ quality test page from the control panel to see if they defect shows on all pages. If it does then you may have a bad transfer belt.
Aug 24, 2016 | HP LaserJet 5550 Printer
Occasional 1/2 inch wide vertical column of color printing on page
Yes absolutely the PCU problem, contact your nearest shop to check the PCU before anything will happen to your printer.
Please rate me solved you decide to check the PCU. Don't look for another solution because I got already the right answer which already suspected at your own guest.
Best regards,
Philip
Nov 12, 2007 | Epson ACULASER CX11NF All-In-One Printer
My HP CP2025 printer will not print color text and color shading in Word. It prints color photos, pdfs, and paintbrush files, but will not print color in Word or Word Perfect.
I had this problem on Windows 7 64x.
The solution that finally worked for me:
1. Go to your Devices & Printers window. (from the Start menu)
2. Right-click on your HP CP2025 printer and select Printer Properties.
3. Select the Device Settings tab.
4. Scroll to the bottom where you see Device Type. It probably says "Auto Detect."
5. Click on the words "Auto Detect" to activate a drop-down menu. Select "Color". Click the Apply button.
To test if this fixes your color printing, go to the General tab and click the Print Test Page button at the bottom. The page should print the Windows logo in color at the top of the page (the rest of the page is b&w).
Note: I did not install any additional drivers from HP for this printer. Windows automatically detected it and installed HP's Universal Print Driver PCL 6.
Kudos to Ken from the HP forums for this knowledge: http://h30499.www3.hp.com/t5/Printers-LaserJet/CP2025-Won-t-Print-in-Color/td-p/1151762
Feb 10, 2011 | Office Equipment & Supplies
Won't print words!
sounds like a couple of things....
the document program your using, when printing, check to see what is printing (pages) you can select one, current page or multiple. also check the attributes for printing.
check the settings for the printer, you might be out of ink
lastly, in the document, go to the Page File and scroll down to see if the shaded areas need to be 'set to back'
hope this helps and good luck
Apr 29, 2010 | Brother MFC 490cw Color Inkjet...
My f340 all in one printer-scanner and copier, is copping very slow from the start copy
Hi theodo13
If your document has typing and line drawings only the printer will priint according to the speed they claim to have.
However if there are few photos, scanned images or color shadings, the printer becomes very slow.
Try to print a page of typed text only, then you will know there is actually a problem with the printer.
Have a good day
luciana44
Nov 28, 2009 | HP Deskjet F340 All-In-One Printer
Colour printing coming out with lines throughout print - shading
my color prints have proper colors but lines come through all through the print even using the best canon photo paper
Jan 23, 2009 | Canon SmartBase MP730 All-In-One InkJet...
Problem with printing smoothly
Hi morshi. I found a potential solution to your problem with your 5610 printing vertical lines at HP.com:
Vertical black lines or streaks
It's hard to tell from the rest of your message what other problems you're describing. I did find a troubleshooting page at HP that shows how to address general print quality problems:
Problem with quality of copies
If those links don't solve all of your problems, the Color printing issues page for the 5610 at HP has numerous other solutions:
I know the name of that last link may seem misleading since you haven't described color printing issues, but the links on that page offer different general print problems and their solutions.
Good luck.
Sep 30, 2008 | HP Officejet 5610 All-In-One InkJet...
3d effect
Shading with a black cartridge will be different than shading with a color cartridge. Replace the black cartridge with a color, and things should return to normal.
On the re-fill cartridge, replace it with a new OEM cartridge, and if that works, the refil is defective.
Dec 31, 2007 | Lexmark JetPrinter Z12 color InkJet
HP OfficeJet Pro 1170c InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
