Question about Mitsubishi WD-52628 52" Projection HDTV
I replace my bulb,and now the green light is blinking and i have no picture,sound or anything..please help the super bowl in sunday!!!
    Scholar:
  • 130 Answers
Make sure you've cleaned out the filter and used a can of compressed air to clean everything out.
If that doesn't work, you may have other issues with your TV such as a ballast or color wheel. Maybe even power supply? You need to listen to the machine for sounds like clicks or hums or whirs. Those are great indications on what's wrong.
Also what happened to make you want to replace the lamp in the first place?
Maybe the lamp you purchased is defective? Make sure to get OEM parts, or with your Mitsubishi, use Philips or Osram only.
Posted on Feb 05, 2010
I have the KDF-50E2000 Sony I have replaced the bulb and I have a solid green light which isnt blinking though could the replacement bulb be the issue
So you do have a picture? Albeit dark blue? Then its the source and/or video connection that is probably the problem
Mar 18, 2014 | Sony KDF-50E2000 50" HDTV
I had to change my bulb about 6 months ago and now i'm having the same problem. i checked the bulb to make sure it was still intact and indeed it was. i'm wondering if there is some kind of switch to...
Ur tv probally also have the board call the Ballast board is also dead beside the projection lamp was replaced before.This board call the Ballast board job is to help to ignite the projection lamp.About an hour before the Super Bowl.Unplug,replug the tv back about an hour later for the tv for the Ballast board might have some juice left to ignite to light up for projection lamp for the last time to have tv picture to the to watch the Super Bowl.Must replaced the Ballast board.
Feb 05, 2011 | Toshiba 50HM67 50" HDTV
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
CHANGE BULB SOUND WORKBUT NO PICTURE.GREEN LIGHT
If you still have red light , it means the temperature of the lamp is too much. Did you buy the original part number of the lamp.
Jul 24, 2009 | Televison & Video
XL 5200 bulb replace and NO Picture or Sound
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
May 30, 2009 | Sony KDS55A2000 55" HDTV
Panasonic pt-lcx70
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 18, 2017 | Panasonic PT-61LCX70 61" HDTV
Sanyo 42"Plasma TV DP42746 No Picture
a thousand or so people have experienced this problem! I am a military spouse and our same tv did the same thing on Super Bowl Sunday 2009! We did everything we know to do: call the company, called the repair man, etc. There apparently isn't a solution to this that wouldn't cost more than the tv is worth. So I got an attorney to start a class action:
If you would like to be compensated for your TV please contact me @
Danimimozi@gmail.com
Jan 24, 2009 | Sanyo PDP-42H2A 42 in. Plasma Television
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung 1080i
ic chips are no good if u can open it up get fan on it blow dust out for super bowl keep it cold
Feb 03, 2008 | Televison & Video
Keeps going black and coming back on - green light blinks
Our tv is about 2 1/2 yrs old and did the same thing we had to replace the bulb and bulb driver board this fixed the problem
Jan 27, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi WD-52628 52" Projection HDTV Logo
174 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
