Question about NEC DTU 8-1 Corded Phone
Connect/Program Headset I would like a headset. However, I was told that regardless of phone type, a HEADSET button will still need to be programmed by a technician. Is there anyway that I can setup it up myself without paying technician to do it? I am tring to hook up a Plantronics Practica S50 to my NEC DTU-8-1 phone system. Thank you
  • 149 Answers
Sure you can do it. as long as the headset has a plug for the handset your fine. Plug it in and you will have to pick up and hang up the handset as needed. The headset key eliminates you having to pick up and hang up the handset to answer with the headset.
Posted on Nov 18, 2008
Just purchased a headset to use with my Mitel 5212 phone but I can't connect it. It's plugged into the back of the phone. All instructions i find tell me to press the headset key on the phone but I...
you have to program a headset button on the phone or hit the blue key (superkey) then hit no until you see headset mode then you can turn it on or off. if you don't see it you will have to login to phone system and program it.
Aug 05, 2011 | Mitel 5212 IP Phone
Cannot connect headset to the base. The set is mute.
Program a headset button on one of the flexible buttons
1) press program
2) press button to program
3) dial 67
4) press enter or store button
5) press program to end
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
I have two Bluetooth-enabled devices from Motorola: (1) DECT cordless phone (B802) and (2) headset (H790). They are paired. I can use the headset to answer calls, however, I can't make headset to work when...
If this is happening while the headset is connected either the Motorola or DECT, then there's a problem with the small circuit board or the program of the headset. Small electronic devices have their program called the firmware.
BUT first, try using another Bluetooth headset and connect it to both phones (one at a time) and then test it with outgoing call. If it does work, then the problem is isolated with your problem headset.
For this kind of problem, you need to contact the manufacturer of your headset for repair.
Good luck and have a great day!
Jan 13, 2010 | Cell Phones
Problem using headset - why the handset has to be off hook
Be sure the headset you have is compatible with the Merlin Magix and a 4424 L4D+ phone. You will need to program both the headset status and headset hangup buttons. Headset status will negate the need for lifting the handset. and the hangup button is used to disconnect the call.
Apr 09, 2009 | Avaya Merlin Magix 4424D+ Telephone
How do you program phone for headset mode on sts phone and where do you plug it in?
Some phones have jack on the side of the phone. If it does not, you will need a standard telephone headset with amplifier. You will need a handset button (634) programmed on the phone. Then in programing Flash 50 button 4 you will need to disable speakerphone. Flash 50 button 18 determines the headset type: 0-is amplified unit plugged into handset cord, 1-is 2.5mm jack on side of phone,
To use handset, press handset button so it is lit, use on off to answer calls with the handset.
Mar 05, 2009 | Vodavi IP7024LD Corded Phone
Headset on DTU 8D-2 corded phone
If you are using the headset jack on the phone, a headset key needs to be programmed on the the phone. You can do this in program mode and make a line key a headset key. Otherwise you must connect it through the handset. ldtsnj.com
Aug 26, 2008 | NEC DTU 8D-2 Corded Phone
NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Jun 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
My phone
Pairing your Cell Phone to your
Bluetooth Headset:
(FROM Bluetooth Headset)
1. Make sure Bluetooth Headset is fully charged!
2. Hold down talk button (center button of headset) up to
(Five) 5 seconds, then WAIT until you see a solid blue
light then immediately flip open earpiece part of headset.
THIS MEANS the HEADSET IS NOW IN PROGRAM MODE.
AT THE SAME TIME/ WHILE BLUETOOTH
IS STILL OPEN & IN PROGRAM MODE….
(FROM CELL PHONE)
1. Click on “Menu” (Left Button)
2. Scroll to Bluetooth icon. (Lower Right Hand side of menu)
3. Click “Ok” button
4. Then click on “My Devices
5. Click “OK” again
6. Select “FIND NEW”: Cell phone searches/connects to pair up
with Bluetooth Headset.
7. Once your Cell phone discovers your new headset, select
ADD” or click on the recently paired headset device.
8. You will then be prompted to enter a pairing code.
Use either..
a. 0000 or
b. 1111 or
c. 9999
Congratulations on paring/ connecting your new
Bluetooth Headset
w/ to your new Cell phone!
Jan 16, 2008 | Kyocera Switchback KX21 Cellular Phone
I need to program a HeadSet Button
For the DTU phone on an NEC Elite system:
Memory Block 4-12
put in the port number and the Lkey of the extension you want to make a headset key.
Programmin on a 16button phone, Lkey 11 needs to be lit and will display H SET to verify.
For the DTP phone, it is generally on an NEC 2000, which is entirely different.
Oct 12, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
HELP
You can't program numbers vocally to you headset, you can only program vocally to your phone only if your phone has the voice dialing option. I have a H500 and can inform you of what I know. To turn on, hold button until blue light flashes once or twice, to turn off is the same thing. To pair your headset with your phone you have to hold down the call button until the light stays on then you use your phone to pair. After pairing the headset will flash quickly then discontinue. If you are using your headset and receive another call, you press the call button on the phone to answer the other line and to also release the call. The volume up and down buttons are found on the top and bottom of the headset, up and down is dependant on which ear you wear your headset. To mute, hold both the volume up and down buttons at the same time, this also unmutes the call. Hope this helps!
Sep 08, 2007 | Motorola Mobility H500 Wireless Headset
NEC DTU 8-1 Corded Phone Logo
550 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
