Question about Kenwood Audio Players & Recorders
I am trying to connect three Kenwood pieces: R-42XL, GE-420, DP-520.
  • 1,476 Answers
Let me know what you want to do and I will try to help.
hardrocko
Posted on Feb 06, 2010
How to connect a kenwood kdc 420 to a scosche 88-05 connector?
There are conversion kits available, Google is your friend
Dec 21, 2016 | Kenwood Car Audio & Video
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
My Kenwood DP-j1070 100 changer is finding cds but not playing anything - there seems to be a spring loose on the loading arm - and not quite sure how to repair - thinking this may be the source of the...
The piece of plastic that held the spring in place probably broke off like mine did. I repaired it by drilling a small hole under the bottom of the slot in the arm and connected it with a piece of solid wire.
Dec 25, 2010 | Kenwood DP-J1070 100-Disc CD Changer
Kenwood stereowith A-58 Amplifier, no manuals, so can't set up
mine does the same and it cost 100 pounds to have the output chips replaced
Apr 08, 2009 | Kenwood Audio Players & Recorders
I-Pod Connection to Kenwood R-SE7
it's better to auxiliary,but if the cord of the optical digital it's ok..
Jul 22, 2008 | Kenwood R-SE7 Shelf System
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
Kenwood GE-3i
1 wire might be a remote turn on 4 the lost amp. connect a light tester to the ground wire turn on and off the pre amp and see if the light goes on and off 1 might also be a floating ground wire .
Oct 30, 2007 | Kenwood KSC-WA100 Car Subwoofer
Kenwood DP-J1070
I have been experiencing the same problem all of a sudden. Almost like it doesn't recognize that there is any information on the disc(s), regardless of whether it is a CD-R or Original disc. As I looked closer, I saw there is also a small spring connected at the top on the swing arm that pulls the CD in (behind disc indicator light) but it is not connected to anything at the other end of the spring. Just hanging there...I've never noticed it before.
1) Have you found a solution to get your CDs to play?
2) Does anyone have a clue what the other end of this spring is supposed to connect to? Or know where I can find a detailed diagram of the pieces on this part of the device?
Thanks!
Oct 26, 2007 | Kenwood DP-J1070 100-Disc CD Changer
41 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
