Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Solid Line Across Screen
I have a solid line that appears across about one-half the screen (near the bottom). It ends in a small circle, perhaps the size of a pin-head. When the set is just turned off - and the screen is going to dark - the line remains until the set is powered off completely. The line appears dark against a lighter background and appears light against a darker background. Any ideas??? (Thanks.)
    Sergeant:
  • 395 Answers
Suspect the Light Engine part # 939P977010
Posted on Feb 21, 2008
Solid lines print across the paper
It is usually caused by the drum. The lines are vertical? perhaps the drum was scratched and needs to be replaced.
If you replaced the toner before the lines appears, the printer needs to be cleaned.
Nov 02, 2009 | HP LaserJet 4 plus Printer
Blue circles on images forehead, cheeks and chin.
Try cleaning the contacts on the connectors going into and out of the Tcon board, if that doesn't fix it replace the board, here is the manual if that helps.
Samsung HL S4266W Owner Instructions Manual
Jan 06, 2018 | Televison & Video
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Horizontal Blue Line
WHEN YOU HAVE A SOLID BLUE LINE THAT DOES NOT MOVE...YOU HAVE A DEFECTIVE PANEL...LIVE WITH IT OR REPLACE PANEL..NOT COST EFFECTIVE TO REPLACE PANE....JOE ACE
Jun 13, 2008 | Westinghouse TX-42F430S Television
Solid white horizontal line
ha ha ha ha ha ah ha ah aha aha a a hah
May 04, 2008 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
