Question about Hurricane Pride PMV Mobility Scooter - Viper Blue
The scooter runs but super slow, I purchased two brand new batteries but it continues with the same problem.
  • Hurricane Master
  • 1,263 Answers
Is there any change speed when you change from 4mph to 8mph ?
if not first check the controller under the seat, normally a black box, make sure that all connection onto the controller are clean and tight,
Check the motor brushes, undo the screw caps carefully,these can be brittle , remove the brushes clean , make sure the brushes move freely within the motor,
Check the brake on the side the motor, this normally has a freewheel attached to it,
Remove the brake unit but do not disconnect the two wires, and test again is the brake clicking when you power away, if not it's not releasing hence the slow speed, check the brake for open or shorted connection.
Regards
GeWiz.
Posted on Feb 08, 2010
  • Robin Hill
    Robin Hill Feb 17, 2010
    Can you please vote if you find my suggustions helpful ?
How often do I charge invacare Leo mobility scooter?
when the batteries run low
there should be a volt meter for this indication or when the unit slows down
Jul 10, 2016 | Invacare Leo 4 Scooter Scooter Silver -...
My electric scooter hesitates, then goes, hesitates, then goes without letting up on the throttle
Going and Slowing is usually a problem with the throttle pot. They are often easy to fix yourself with a bit of WD40 once you have found out where the throttle pot is on your machine. Sometimes they have to be replaced, but fortunately the part is quite cheap. You didn't say what brand your scooter is, but Pride scooters are known for throttle pot problems.
Sep 16, 2014 | Electric Mobility Merits Electric...
Panther lx4 runs irregularly .batteries are brand new. ride well for 10 minutes after it starts to slow down then accelerate then slow down etc...
Most scooters have only a rheostat to control speed. Over time, the carbon will wear and cause erratic control.
Oct 14, 2013 | Invacare Panther LX-4 Batteries
New battery. hooked up correctly. But, scooter will still barely go in reverse super slow. forward speed slow .can throttle cable be problem/ when I push inside of speed lever it moves faster. pushing ends...
Hi. Did the machine used to operate properly in the past? Sometimes previous owners or technicians have changed the programme for owners for different uses. What you describe sounds like a faulty throttle pot ( Wig Wag ). I have changed many throttle pots for this reason.
Also check battery and motor connectors.
Do you have another switch on the machine for controlling the speed, such as an indoor/outdoor switch? Good luck. Neil.
May 12, 2010 | Activeforever Lynx L4 Portable Mobility 4...
Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
Oct 03, 2009 | Invacare Pronto M51 Power Wheelchair
Scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
Feb 07, 2009 | Pride New Mobility Victory XL 4 Wheel...
I AM ONLY GETTING 9.3 VOLT TO THE MOTOR
Just to be sure have the batteries tested with a load tester. Then ohm test the brake. It should be around 35 ohms.
Dec 21, 2008 | Pride New Mobility Legend 4 Wheel Scooter
Hurricane Pride  PMV Mobility Scooter - Viper Blue Logo
1,461 people viewed this question
Top Hurricane Health & Beauty Experts
Robin Hill
Robin Hill
MobilityRepairSpecia...
Level 1 Expert
Jeff Tilburn
Jeff Tilburn
Are you a Hurricane Health and Beauty Expert? Answer questions, earn points and help others
