Question about HP LaserJet 1320NW Printer
HP 1320NW PRINT IS FADED ON THE LEFT SIDE BUT OK ON THE RIGHT,SWITCHED PRINT CARTRIDGES BUT STILL THE SAME
    President:
  • 2,306 Answers
Try taking out the toner cartridge and using a soft cloth to wipe the narrow window that is above where the cartridge sits inside. The window gets toner on it and blocks the laser path writing to the drum.
Posted on Feb 05, 2010
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
I have a Samsung CLP-620ND color printer, only 1085 copies printed. After changing the 3 colored toner cartridges, my print out came out bad. Left side of paper around 3
Dear
Open the individual carts from the printer and visually observe the density of toner on the developer roller evenly. Some times the cleaning blade of ITB over come the problem.
Before this try to adjust altitude and cleaning on EPM or smart panel from PC.
Thanks.
Mar 15, 2012 | Samsung CLP620ND Colour Laser Duplex...
I no longer have my manual, how do I change the ink cartridges for the HP Officejet 6300 all-in-one?
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
3. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge. The HP Inkjet Supplies Recycling Program is available in many
countries/regions, and lets you recycle used print cartridges free of charge. For
more information, go to the following website:
www.hp.com/hpinfo/globalcitizenship/environment/recycle/inkjet.html
6. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
8. Close the print cartridge door
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
11. The HP All-in-One aligns the print cartridges. Recycle or discard the print
cartridge alignment sheet.
12. Press OK.
Jul 17, 2011 | Computers & Internet
Good day, i have a 4730mfp. it does not print colour correctly, the print out appears faded like the printer is out of toner, even after all toners are changed.
First thing to try is this, please go to control panel on the printer and to aministration menu. Scroll down to troubleshooting and find the PQ troubleshooting option and press ok. This will print a series of test prints. If these prints look OK then likely you have an issue with your driver. If they are faded, the second thing you need to do is check to make sure that your firmware revision is current. On the config page that prints with the pages just printed above, look on the upper left for firmware revision. Current version is 46.300.0. Download from here and install following the instruction in the readme file. Did it print OK before changing cartridges? If you installed remanufactured or 3rd party cartridges, the toner will not always provide the same quality of print.
Mar 16, 2011 | HP Color LaserJet 4730xs MFP Printer
Sir ihave printing problem when i print a page on the left side margin impression faded there is some faded portion of teflon roller crieate this problem please assist me how to solve this problem ...
sir ihave printing problem when i print a page on the left & right side margin impression faded please assist me how to solve this problem regards KULDEEP SINGH BISHT
Aug 09, 2010 | HP LaserJet 1020 Printer
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Align the print cartridges
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
cartridges ensures high-quality output.
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
I am getting a cartridge error. The cartridge is not a new one and it had not been removed. I followed the insructions in the book for cleaning the copper colored contacts but to no avail. I have turned...
OK, If the printer has 2 or more print cartridges, then certain cartridges must be inserted into the correct carrier. Make sure you have not mixed / switched the cartridges into the wrong carrier..
ALSO, What printer model number? And, what is the cartridge number?
Nov 20, 2008 | HP Office Equipment & Supplies
Faded print job
ok...have you tried a clean and re calibrate lately on those print heads?
Mar 20, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP LaserJet 1320NW Printer Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
