I have an Omnitech monitor that shuts itself down and the only way to bring it back is to turn off everything and on. what to do. I bought it less than a year ago
I had someone come in to my house and check mine, it's not the cable...I tried a new cable. Its the monitor. U need a new one
Posted on Jun 07, 2010
    Guru:
  • 239 Answers
It may seem strange but this prob may be related to the cable connected to ur Harddisk.. replace it n c
Posted on Feb 05, 2010
Omnitech OM19WD PC monitor
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 03, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Hp slimline computer cannot bring up keyboard and monitor
Buggy Motherboard... could be the BIOS could use an upgrade, Bad Battery on MB, or MB could just be bad. Data on you drive is good and recoverable. New PC ? Buy.com a Referb Box is a good choice if you are on a budget. A Turion Processor is not worth the expense to fix in my opinion. If you can do it youself,for fun, replace Motherboard, HD and CPU and re-use the rest. Buying a new one, even a real cheep one is a less frustrating solution.
Dec 31, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Monitor turns on for less than a second, then off. I bought a 19" Samsung LCD monitor (953BW) about 10 months ago and the first time I used it, it would only switch on for a split second and shut down. ...
Although the OP was 2009. I had this problem.
I simply replaced the power board. Which I bought from ebay for $20AUD.
It was real easy to remove as well. Just have a look for youtube videos.
Fixed!
Aug 31, 2009 | Samsung 953BW LCD Monitor
The monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Aug 08, 2009 | Princeton Digital Computers & Internet
L1932TQ LCD Monitor won't turn on.
I'm affraid you did about everything you can to find the issue. Trying to isolate the problem is the best way to come close to a solution eventually. But after all the tests you did, it seems that the monitor itself got a problem. I dont suggest you to try to fix it yourself, some electrical parts may need to be electrically discharged before being removed from the monitor. If your monitor is still in waranty, contact LG for support. Otherwise, you could bring it to a local tv/monitor store to see if they can repair it. LG support rep could also give you some advice, maybe they got a certified partner in your area that could take a look at it. P.S. If your computer is on windows XP it should shut down the usual way just by pressing the power button once. The shutdown will be the same as if you go Start->Shutdown->Shutdown the computer.
Jun 03, 2009 | LG L1932TQ LCD Monitor
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
Shut off itself
sounds like you might have an auto overvoltage shutdown circuit kicking in. The hivoltage goes to high and the monitoring circuit auto shuts down. More than likely trouble is in hivoltage circuitry. If you have a transformer that will allow you to bring up the set slowly without shutting down and you can look to see what's happening.
Feb 16, 2009 | Sharp 25R-S100 25" TV
Buttons no longer work--power and OSD menu buttons don't work
I had the same problem. In frustration after trying everything else as I couldn't shut the monitor off, I shut the computer down, unplugged the power to all, and left it until this morning (12 hours). Now it works, so it must reset itself. I am waiting for feedback from their support as well but imagine they will tell me the same, good luck.
Jan 18, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor shuts down unexpectedly, can't bring it back up
Please verify your monitor screen saver options.there u can find power button.by selecting that button u need to change turn off monitor option into never.then your monitor never shuts down unexpectedly.
Sep 14, 2008 | HP Computers & Internet
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Computers & Internet Logo
385 people viewed this question
David Payne
David Payne
