Question about Motorola Mobility I335 Cellular Phone
My i290 was working fine this morning, I went back and it says, "no service". I can't access my main menu to reboot. I tried turning it off for hours. Plus, the website says my phone is active. Any suggestion?
How to fix my solarized tv?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
May 16, 2016 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
My Hitecker 32 inch TV suddenly will not show any inputs other than TV. Worked fine last night. Doesn't this morning. No power surges that are known about overnight.
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 01, 2014 | Televison & Video
Wharfedale LCD3210HDAF blank screen
Wharfedale LCD3210HDAF this tv was working fine the night before .. when i turned it on in the morning the screen came on then instantly went blank .. although the sound is fine i am unable to get any on screen including menu an volume information and of course can any one help ??
Oct 27, 2009 | Televison & Video
My motorola i290 won't turn on no matter what!
I FINALLY GO IT!!!!!!!!!!!!....take the battery out 4 a few secz n pop it back
Aug 04, 2009 | Motorola Mobility I335 Cellular Phone
Hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Dec 18, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
MY GUIDE 3000 GPS Device
Try asking someone else, have you tried updateing the firmware on the gps?
Jul 15, 2008 | GPS
Can't get back to main menu
switch it off and try to start it again
Jul 11, 2008 | Coby MP-C7085 MP3 Player
Grundig colour tv lost digital channels
I'm sorry, but I have not worked with Grundig TV's, radios yes, TV's no. However, The menu shouldn't be hidden. The first thing I would try would be to UNPLUG the set from the wall, wait about a minute and plug it in again. This action should reboot the micro processor. On some sets, there are two levels of menus, main and advanced. You would want "channel setup" and /or channel scan. You may also look in the back of the manual and see if it list some service dealers that you could call for help. I hope this helps.
Electrode
Mar 03, 2008 | Televison & Video
Motorola Mobility I335 Cellular Phone Logo
15 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
