Question about Jenn-Air JCD2389G Side by Side Refrigerator
Water in front of fridge
I have had this happen before
I had a repair guy come out and replace some part that pertained to the defrost systom.
Cant find the old bill.
Looking to find out what the part could have been.
  • 27 Answers
The drain in the freezer is clogged. Remove racks, take off back panels. the drain is in the very back of the freezer under the cooling coils. You will see an aluminium tray the drain is in the middle. Use a pipe cleaner of some kind to clear the drain. Then flush with hot water. Don't push to hard or you may push the rubber drain tube off. Empty evaporator tray after.
Posted on Feb 23, 2008
Psc25pssc ss
If it has auto defrost the temp shown will go really high but only for a short while. It sounds like the defrost timer may be faulty if it is defrosting products
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I've had this problem before, where the fan is frozen so the fridge is no longer cold but the freeze is OK. What the guy did last time was remove the floor of the fridge, and poured hot water on the fan...
fridge not going into defrost, freezing up coil, replace defrost control, should thaw out fridge, or your evaporator fan motor is burnd out, thaw fride first see if fan works, if fan ok ,derost timer, if not relace fan motor
Sep 06, 2010 | GE GDS20KBS Bottom Freezer Refrigerator
Have a GE profile model # PDE18LBRARSS refrigerator the freezer works but the fridge is warm, when I turn down the fridge the fan cuts out,so I don't think it's the fan.
We have the same fridge and same problem.....our fan is freezing up. We have had to take the bottom panel out and use a hair dryer to melt the ice around the fan (serveral times!) I dont know what the solution is or why this is happeneing (we have the temp set very low).
please help.
Jan 01, 2010 | GE Monogram ZIC360NRRH Bottom Freezer...
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Frigidaire side by side, water leaking onto bottom of freezer
If you looked at the back section of the freezer (inside) and found ice then you need to completely defrost the fridge freezer. What you are describing is a frozen evaporator and the freezer needs airflow to work properly. If the unit starts behaving normally after defrosting then you need to monitor it closely as they will normally start playing up again after 2-3 weeks. If it does fail again then you probably have a defrost problem normally the defrost heater but can also be the defrost timer o defrost sensor. If it fails to reach temp then I would suggest contacting a decent repair guy who should be able to diagnose which one within a reasonable time. I would recommend defrosting first though because the same symptoms can happen when a door is left ajar. Hope the above is of some help.
Sep 14, 2007 | Refrigerators
Jenn-Air fridge not cooling
we had same problem with brand new refrig.
Serviceman just left - he replaced part  with label
"ADAPTIVE DEFROST ENCL.
61005988. I hope this works.
Aug 13, 2007 | Jenn-Air JCD2295K Stainless Steel Side by...
Auto defrost not working correctly
the tray at the bottom which collects defrost water usually has its own heater or a section of the main heater runs close to it. check this part of the heater has continuity. an old trick as well which sometimes works is to wrap some copper wire round the heater and lead this to the drain hole. conductiuon of heat thro the copper helps keep the drain clear. this is a common problem across all makes
May 08, 2007 | Whirlpool 18.2 cu. ft. Top Freezer...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
77 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
