Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Bar is not getting lubed. I have thinned the bar oil with coal oil. The syphon tube is in place.
    President:
  • 2,220 Answers
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
Example IPL Poulan 2375LE Gas Saw Type 2 (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Oiler components are on the "Handle, Chassis & Bar Assembly" print.
It has an outboarb clutch if necessary use this as a guide for removal. I think you need the special tool (Google Search):
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If the example is not your saw it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If You have more questions or need more help reply below and I will get back to you. HTH
Lou
Posted on Feb 06, 2010
Where does the impulse line go to from the engine block.?
There are two "impulse line(s)" on a typical "2 stroke chain saw.
One goes from the intake or crank case to the carburetor to drive the diaphragm "pump". Sometimes this "line" is built into the intake or transfer port and back to the carb by passage ways drilled into each and mating thru the gasket. The pressure pulses drive the "pumper carb" to deliver the gas, whether the upside down, sideways or vertical.
The other impulse line will go from the intake or crank case (between the carb and crank case) to the chain oil reservoir to lube the chain.
The pressure pulses (pos or neg) will drive the very simple oil pump to lube the chain thru passageways and/or tubes between the "bar oil" tank and the engine case where the chain bar is clamped to the engine. There are crossing slots in the case and bar that allow oil to flow and the bar to be adjusted in/out to tighten the chain. An internal passageway in the bar from the crossing slot to the chain groove gets the oil to the chain. Always be sure to clean these passages with a copper wire periodically as they tend to get clogged with very fine wood shavings.
May 10, 2014 | Poulan Garden
The chain oil leaks at all times model 345
There is an adjuster screw on the bottom of the saw, that has three settings. It sounds like it is turned up to high. After you adjust it to a lower setting, start the saw and then put a board in front of the bar. Rev the saw up while the chain is going and you can see lines on the board made from the oil. I usually make three lines to determine how much oil is lubing the bar. Also, lube the bar tip if you have an lube hole on your bar. The lube hole is about the size of a ink pen head. You will have to purchase a bar tip luber from your dealer. They are inexpensive and will save on bar life.
Nov 14, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
It won't automatically oil the chain. I've put very thin oil in and it sitll doesn't oil. I've taken the breather tube out and cleaned it. Not sure what else to do.
Release the chain brake, then remove the bar and chain. Clean the engine where the bar fits up to, start the engine, and look for oil oozing out of a small port in the engine side. Make sure to replace the thin oil with regular bar oil. If the oil does ooze out, then clean the small oil passages in the drive end of the bar--they run from the large holes out to the chain groove on each edge of the bar. If no oil oozes out, check the oil filter inside the tank. If ok, then the oil pump requires service--it is located just behind the clutch drum on the crankshaft. The clutch has left-hand threads and can be difficult to remove--you might wish to farm the oil pump repair out to a service shop that has the proper tools and procedures. Hope this helps!
Nov 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
NOT GETTING LUBE TO CHAIN
Remove the bar and chain. Clean the oil port in the engine side where the bar fits to. Start the engine and look for oil oozing out of the port. If ok, clean the bar drive-end oil passages that run from each large hole out to the chain groove on each side. Clean the entire chain groove, then reassemble the bar and chain. Tighten the chain until it pulls up to the lower bar edge, but not so tight that you can't turn the chain by hand. Recheck tension again after tightening the bar cover nut(s). Start the engine and run at speed for several moments with the bar tip near some cardboard--it should throw off a thin line of oil. Hope this helps!
Sep 05, 2010 | Husqvarna Chain Saw 20" Bar
How to clean chain lube port?
Remove the bar/chain, then blow the area clean with compressed air. Run the engine until it oozes out some fresh oil, then wipe the area clean. Make sure the small oil channels are clean where they go from the large holes in the drive end of the bar out to the chain groove on each side. Clean the entire chain groove as well. Reassemble the bar and chain and adjust the chain so that it comes up to the bar, but not so tight that it can't be turned by hand. Run the saw at speed for a few moments with the bar tip near some cardboard--it should leave a thin line of oil. Hope this helps!
Aug 11, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How much chan lubricant should be used and what is the grade of the oil
You want to buy Bar grade oil, it is sticky and stays on the chain, it will properly lube the bar and chain with a full tank o gas. People have used, used motor oil but this wears down the chain and gears from the micro sized filings in the oil so use clean bar oil to lube the chain correctly. also if the chain sprocket has a small hole in the tip of the saw you will need to buy a gear lube pump to keep grease in the gear at the tip of the blade. This should be lube each time you fill the fuel tank and once half way threw the tank of fuel to make the bar last longer. The bar oil is a special grade of oil and requires bar oil for it to adhere to the bar and the bar guides. Hope this helps and thanks for using fix-ya.
Jun 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Bar lube is having trouble come from the small hole located behind the bar . Is the lube pumped though or is it cravity feed.? When i remove the bar and chain , start the motor a very tiny amount will...
There is a pumped volume adjustment screw located near the rear case bottom and the lower part of the chain. Turn CCW somewhat to increase volume. Be sure to clean the bar oil passages including the two small channels that run from the large holes out to the chain groove on each side. Clean the entire groove. When everything is back together, run the saw at speed with the bar tip near a piece of cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Jun 08, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Hot bar loose chain
Remove the bar and chain from the engine. Clean the side of the engine where the bar fits, start the engine and run fast for several moments. Oil should ooze out of a port and run down the engine side. If nothing, then the oil lines, valves, tank filter, and the oil pump (behind the clutch assembly) should be checked for plugging, breakage, or other problems. If oil comes out, then clean the oil holes in the bar drive end including the two small holes that lead from the larger holes out to the chain groove on each side. Clean the entire chain groove. Oil and check the end sprocket for smooth, relatively free turning. Compressed air is very useful for cleaning these parts. Reassemble bar and chain making sure the adjustment tang drops into one of the large holes--you may have to back off the adjustment several turns to make this work. Make sure the chain cuts toward you on the bottom run and install the clamp nuts/bolts finger tight. Adjust the chain until it pulls up to the bar and you can turn the chain by hand. Run a line of oil around the chain to pre-lube it. Tighten the clamp nuts and retest the tension again. If ok, start the engine and run for several minutes, then place the tip near some cardboard and run at speed for several moments--it should throw off a thin line of oil. Make sure the chain is fully sharpened then try a few cuts. It should cut smoothly without any undue pressure from you. Hope this helps!
May 15, 2010 | Husqvarna Chain Saw 20" Bar
Poulan pro series chain saw 20" bearings seizing up on bar
check sprocket isn't worn it may be pulling on chain than over heating bearing. check pitch of chain ,bar , sprocket are the same.
Dec 29, 2008 | Poulan Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
91 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
