Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
My ps2 controller wont work atall when plugging it in connector port
  • 163 Answers
Have you dropped it?
If so the components inside are probably damaged.
I think the best solution to this problem would be just to purchase a new controller, as it is not worth the hassle to taking it to pieces as they can come fairly cheap on many online auction websites.
Hope this helps!
Posted on Feb 05, 2010
All my controller buttons dont want to work but the controll looks fine all the buttons click ok its like new but it wont work
Well, there might be several things wrong with your controller. Now, that being said the most likely thing wrong with it is the connectivity. Feel free to just stop reading if any of these steps fix your problem
1. Check that the cord is properly plugged in to the correct port.
2. Take the cord out of your PS2 and check all the connectors (they look like brass strips on the inside of the plug). Are they bent? dirty? do some appear to be missing?
3. If yes, try cleaning with a can of compressed air, then plug back in.
4. Reboot your PS2 then re-plug it in.
5. If none of these things work, or if the light in the center isn't on, then your best bet is to take the controller back to the place of purchase and ask for a refund.
Feb 28, 2011 | Sony PS2 Dual Shock 2 Controller...
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
How do i connect my PS2 with my PC
on the back of your computer box, you will (probably) find 2 ports that look like this. the PS2 mouse will be plugged into the green colored port. NOTE: PS2 mice (and keyboards) will only fit into the port ONE DIRECTION, so don't force it! make sure to line it up
once plugged in, you will need to reboot your computer, as PS2 can only be recognized while the computer is starting up.
one final note: some of the newest computers DO NOT have PS2 ports. if this is true of your computer, you will need to get a new mouse, or an adapter, like the one shown below:b6b70e7.jpg
Aug 27, 2009 | KEIO PS2 Optical Scroll Mouse
My ps2 anolog dual shock controller wont work!
It could be the PS2 connector port.
1) Try cleaning it. Maybe used compressed air or just blow into the faulty connector port.
2) Something more challenging, is to maybe open up the PS2 and to search for any broken connections between the Ps2 controller port, and the Motherboard of the PS2. Use a phillips #0 or a phillips #1 screwdriver, flip the ps2, you will see all these tiny squares, pull them out using something sharp, and underneath them there will be the screws, also there are some screws located underneath the warranty sticker and another underneath the Info sticker, just probe the surface until you land upon a hole. there you will find the screws. Open the ps2 up and you will spot the connector and search for any broken connections. any broken links can be fixed just by using a soldering iron and some solder.( OPENING UP YOUR PLAYSTATION VOIDS YOUR WARRANTY).
3) IF your ps2 is still under warranty, you can send it back to sony, or one of their many repair centres around the nation( IF U ARE IN THE USA). If in another nation, you can visit sony.com and follow their instructions on how to go about with in warranty repairs
Dec 29, 2008 | Sony PS2 Dual Shock 2 Controller...
My PS2 controller port stopped working!
Sounds as if it has been dropped .....or an impact to the controller port while one was plugged in. in some cases the in side of the port can become full of dust and dirt causing light rusting creating a loss of connection ...but an impact can break a small chip on the back of the controller port inside the machine , try cleaning out the controller port and check to make sure the metal tabs are clean and un bent.
Aug 22, 2008 | Sony PlayStation 2 (PS2) Console
The controller port of the ps2
Oh ****, does this mean you're going to have to go outside?
Apr 07, 2008 | Sony PlayStation 2 (PS2) Console
3 red light fixed
check connectors and plugs
Mar 11, 2008 | Microsoft Xbox 360 Console
PS2 power ribbon
Hi Anishpp
If it came loose from the buttons, you need to remove the button holder to get to the connector. Push he ribbon into the slot on the back of the buttons.
If it came loose from the motherboard, you will have to remove the guts of the PS2 to see the connector under the cd drive right side. This is done by removing 4 screws. Two are on either side of your Controller ports. Another one is located between the fan and power block. Another is to the left of the powerblock. lift the guts from the back and pull the system out. looking at the right side, plug the reset Eject ribbon into the 2nd connector from the front. Then put it all back together carefully.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 controller port wont work
There is a problem with the controller port PCB. Either one of the pins have snapped or a component on the Controller port board has broken down.
Can be easily replaced with a spare off an auction site.
Jon
Oct 13, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 multi-tap
I had this same problem. Try plug the multi tap into the player 2 port (with a controler in the player 1 port) and so on try different arangement for the controllers (mine worked with the way i wrote). If this doesnt help, a friend of mine had a problem with the contacts in the muti tap (or the controlers), if you are experience you could try open it up and make the contacts stick out a lil more or (more preferably) contact the producer of your multitap they may be able to repair it for a decent fee
Apr 06, 2007 | Sony PlayStation 2 (PS2) Console
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
555 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
