Question about Nikon LS 30 Film Scanner (35 mm)
Film feed only a quarter completed each time - Nikon LS 30 Film Scanner (35 mm)
Hold scanner at height of 2m and drop onto a hard surface!!!
Posted on Nov 26, 2010
I need a manual for Bell & Howell Lumina MX60 for an elderly person - need instructions how to load film.
Spec says it's auto-load. From what I recall of my own projector, you mount the input film reel on the front 'arm', extending it as necessary to give clearance, switch on the projector, then feed the free end of the film into the appropriate orifice at the front of the projector.
It then takes over, feeds the film through and wraps it around the take-up spool automatically. It may be necessary to cut the end of the leader on a diagonal to feed it in (not each time the film is loaded, just the first time.)
Once the film has fed through, switch on the lamp, focus and enjoy.
Dec 30, 2016 | Bell & Howell Cameras
How to clear error 6000 canon410
Line Feed error or Error Code 6000
Condition: An error occurred in the LF encoder signal.
Problems and Solutions:
  • Smearing or scratches on the LF / EJ slit film
    - clean the LF / EJ slit film.
  • Foreign material or paper debris in the LF drive;
    - remove foreign material.
  • If other solution fail, replace one off the following
    - LF / EJ slit film
    - LF / EJ timing sensor unit
    - Paper feed roller unit
    - Logic board
    - Paper feed motor
Aug 03, 2015 | Canon Pixma MX410 All-In-One Printer
Film count reading problem
I am not familiar with that model.. However ant time you open the compartment or unlatch it THE CAMERA think you are installing NEW FILM so camera goes back to the "Beginning". is this your first time use??, look for the instructions or google it.
Jun 02, 2015 | Fujifilm Instax Mini 25
Error code 6000 canon pixma mg8120 printer when trying to priint wirelessly
Hello and Welcome to FixYa!
Error 6000 actually a line feed error, with the problem originating from the timing disk film or the printer's logic board.
To solve this problem:
Check the timing disk film or Check the feed roller if is there any foreign body, remove it softly
Timing disk film is located at the left side of the printer
If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
For further help, you can take my valuable,professional help by taking my Service
Thank you for using FixYa!
Nov 15, 2011 | Canon Pixma MG8120 InkJet Printer
It says error code 6000
error 6000, and the LED display E2,3, thia error appears when there is a paper feed problem. to solve this problem:
  1. check the timing **** disk film.
  2. check the feed roller (is there any foreing body, remove it softly)
the timing **** disk film is located at the left side of the printer, look at the picture to identify it:
Dec 06, 2010 | Canon PIXMA MP470 All-in-One Printer
My pixma IP1980 ahs an error and the green at orange lights blink alternately. error code is 6000.. pleasehelpme...
Error code 6000 mean line feed error. Possible problems in:
- Timing sensor unit
- Timing **** disk film
- Feed roller assembly
- Platen unit
- Logic board assembly
- PAPER FEED MOTOR
Oct 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
SA-21will not pull film strip into chamber
Put the film in after it is powered up. The unit needs to run through a power-up and calibrate cycle first. Once powered up, the until will feed the film in once it reaches a certain point into the machine.
The unit is supposed to kick the film back out when you close down the scanning software. If your film ever gets stuck try this to get it out. DO NOT force the SA-21 out of the machine with film stuck in it.
Aug 13, 2008 | Nikon COOLSCAN IV ED LS40
Nikon LS 30 Film Scanner (35 mm) Logo
41 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
