Question about Samsung Televison & Video
Samsung LW15M23C changes source on its own
The TV has started to change source on its own. It changes from TV to AV1 to AV2 to S-video to PC, often getting stuck on AV1. I cannot change the source from the remote (which otherwise works fine) instead gave to use the buttons on the tv itself. However any change only lasts for a couple of minutes at the most making it quite impossible to watch TV. The TV is not connected to anything (no DVD). What should I do?
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Posted on Nov 25, 2008
  • 418 Answers
SOURCE: how do i change from av1 to av2 . . .av3 ? have remote . .
I think you can do channel down, or up, 'til you go below channel 2, or above channel 125. Then it toggles through external inputs.
Posted on Apr 18, 2010
Problem: TV Menu w Auto & Manual Scan greyed out cannot be selected
Check the input selected. if it is other than tuner, this might happen. Change the input to tuner, and check.
Jan 11, 2016 | Televison & Video
How do i get my nintendo wii console to appear on the tv screen ive tried every channel and hdmi and such and nothing i know its on and working cause i feel the wii remote vibrate just nothing shows o
Kate what did you plug the cables into I suspect it was a grey cable with a red , white and yellow plugs. If I am correct this cable should be plugged into the AV1 or AV2 input port of your television. Try changing the input source to AV1 or AV2 Check it is plugged to AV1 on the Television and not into Conponent input !
Jan 02, 2015 | Sceptre X32BV-Naga 32 in. LCD TV
Sanyo tv change to av1 av2
Whenever your change from one video source to another, your tv automatically switches input modes (i.e. av1 to av2) to faciliate the source coming into your tv.
Aug 10, 2014 | Sanyo DS32920 32" TV
How do i get a pictue on my samsung tv?
The input is selected as AV1. Change it to input which you want to see. AV2, HDMI, TV etc:
Jul 27, 2014 | Samsung Televison & Video
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
How do I hook up a dvd player
yellow, white and red wires usually connected to the same name same colors on both devices.
Does the tv need to be on a certain channel? YES, try change to all ex: VIDEO 1, VIDEO 2, DIGITAL, ANALOG, HDMI or any according to tv sysem
Oct 27, 2013 | Seiki Digita Seiki LC46G82 46 in. LCD HDTV...
Can i hookup theis computer to my tv using a hdmi cable?
Yes, your notebook comes with an HDMI port. You will need an HDMI cable to connect to the TV (usually LCD TVs come with an HDMI port). After the connection has been made, change the source in the TV by clicking the "Source" button on the remote. It usually changes in the following sequence - AV1, AV2, HDMI.
Jun 25, 2011 | HP Compaq Presario CQ50-103NR Notebook PC
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
NO AV1 AND 2 VIDEO SIGNAL
tv start working on its own.
Jun 26, 2008 | Samsung Televison & Video
Televison & Video Logo
69 people viewed this question
Jerry Greenberg
Jerry Greenberg
