Question about Kenmore 24032\24036 Top Load Washer
I have a front load washing machine and vibrates like crazy. Any suggestions.
  • 572 Answers
Make sure its leveled. second floors are bad for them. soft floors are bad. recomended for the garage with a concrete flooring. if it has a pedistal it shakes more
Posted on Feb 05, 2010
Wash down
Since down comforters are very light in weight, they confuse energy efficient front loader washing machines in how much water to add. Therefore, very little water is used, which results in a semi-damp comforter at the end of a wash. Pre-soaking the comforter beforehand would help, however, now the comforter weighs a ton, and the machine will vibrate like crazy during a spin cycle. It may be better to have the comforter dry cleaned.
Apr 28, 2014 | LG WM1812C Front Load Washer
Loud vibrating washer
What is the model number of the unit?
Mar 03, 2014 | Kenmore HE2 Plus Front Load Washer
Washing machine is really loud when spinning (sounds like a plane taking off)and if you are sitting on couch one floor down you can feel the couch vibrate and the floor its on shakes like crazy. I was told...
no it is not normal and there so be no reasonable excuse for bad vibrations and shaking on a new machine ,if the setting up instructions and leveling procedures were carried out.
at six months it should be still under warranty so have it fixed under the warranty
Apr 23, 2017 | Maytag MHWZ400T Front Load Washer
I have a wpxh214a ge washing machine.approximately 5 yrs old.suddenly vibrating like crazy.took off front lower panel noticed broken left damper(at the foot where plastic bolt goes through damper.Oddly at...
The machine shut down bwcause of the vibration and if you unplug it it will reset...
but you need to get those shcks changed... they are not that hard to cchange and change both sides right of way...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 28, 2010 | GE WPXH214A Front Load Washer
LG front loaded washing machine vibrates during
If its on a pedistal then that will raise your center of gravity and cause the unit to be less sturdy during a spin. It could also be due to a weak floor. You may want to try a product called "shake away pads". The probably sell them at like home depot or lowes. They will run you about 40 bucks but they just go under the legs and help absorb some shock. Good luck _MJ_
Apr 27, 2010 | LG WM2487H Front Load Washer
Washer vibrates alot
The following link may give you some pointers on what to check on your kenmore Elite to resolve the vibration problem:
http://www.fixya.com/support/r3633026-front_loader_excessive_vibration
This could be a matter of the legs becoming unlevel during the move, a shock absorber becoming damaged, or it could be the new location. These front loaders need a good firm and level foundation. Read through the link provided and let me know if you have any questions. I hope this helps you solve your problem.
Dec 18, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Noise on spin mode fast loud clanking like something in drum
Wow, we're having a similar problem vibrating like crazy...just online to try and figure it out..
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Vibration
use motorcycle strapdowns and large eye hooks
Aug 19, 2008 | Maytag MAH8700A Front Load Washer
Maytag front load washing machine
I have the same problem and its making me crazy.
Feb 04, 2008 | Maytag Neptune MAH9700 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
