Question about Canon PIXMA iP90 Mobile Printer
Pstopdffilter/pstocupsraster failed with err
When trying to print a pdf document to my Canon iP90 printer (bluetooth) I get the following error. All other documents print ok.
pstopdffilter/pstocupsraster failed with err number 13
  • Anonymous Mar 21, 2014
    printing PDF files. nothing more, reinstalled the printer 3 times already.
    Mac OS 10.6.8
    nothing special, located on network, LDP to IP
    has worked for a long time. All of a sudden today it is giving errors.
    no updates done.
    printing pdf files.
    worked for a good long time
    mac 10.6.8
Obviously this is an error coming from Adobe and not the printer. So I was start with Adobe and see what solutions they have to offer. Also, maybe I missed it somewhere, but you didn't say what OS you're using. I'll assume mac since I thing that I've seen that error related to Mac and Adobe Reader. One thing you might try is to use "open with : preview" and print from there. Don't know if that will work or not, but it's worth a try. In any case, I would still inquire through Adobe for possible updates or fixes.
Posted on Mar 09, 2011
  • pclive Mar 09, 2011
Pstopdffilter/pstocupsraster failed with err number -31000
This is a suggestion which may help:- Try changing the print cartridge/s that will be used if the print job goes ahead. I have had the same msg come up just after changing a low cartridge with a cheaper replacement cartridge which had leaked whilst still in its cling wrap(normally I wouldn't install a cartridge like this but I had no other alternative & it did work initially & even after the error msg came up I checked it for leaks & found none. As soon as I refill a propietry one or buy another I will be trying out my own suggestion. I would appreciate it if U can email me of any success U achieve & how U did to "tallmcgowans@gmail.com"
Aug 27, 2012 | Brother HL 5250DN Laser Printer
My CaNON ip90 PRINTER SAYS "ERROR" WHEN TRYING TO
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Mar 08, 2011 | Canon PIXMA iP90 Mobile Printer
Printer error
If you used the original driver software that came with your printer, it probably is not compatible with Snow Leopard. Go here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=79609&prodoid=63066043&infoType=Downloads&platform=Macintosh
Click the download link and save the file to your desktop, then run the installer. This should load the most recent driver. Then go to System Preferences > Print & Fax, if your printer is not listed, click the + to add it. Hope that helps.
Mar 10, 2010 | Canon PIXMA iP90 Mobile Printer
I have purchased a ''Virtually Mint'' Canon Pixma ip90 printer however, when I try to print a document a message pops up stating ''the following ink tank is not installed: black ink tank, colour ink tank....
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 21, 2010 | Canon PIXMA iP90 Mobile Printer
Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Jul 21, 2009 | Canon PIXMA iP90 InkJet Printer
Ip90 printer does not print blac on a test after
Sounds like the printhead is plugged on the black side. A new printhead is #qy6-0052-000 around $40.00. That model also needs a firmware update to help it clean the printhead better.
Jun 23, 2009 | Canon PIXMA iP90 Mobile Printer
Canon IP90 Service error 5C00
BCI - 15 is not the same as the BCI -16. The look and feel the same, but the ink is handled differently by the printer - so while, in theory you could use them interchangable, the output would be terrible... Canon set it so that you can only use a BCI 16 in an IP90.
Buy a BCI - 16 cart and try that.
Mar 22, 2009 | Canon PIXMA iP90 InkJet Printer
Error 5100
where is the best place to get this repaired>
Nov 06, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
1,868 people viewed this question
old marine
old marine
