Question about Bose 901 VI Main / Stereo Speaker
Stereo struck by lightning and i need to fix it...
I am doing a project for a class at my high school and i need to fix a Mitsubishi M-A4370 stereo amplifier that i was told was struck by lightning. i am not sure what to even look for or where to begin...anyone got any advice? sorry about the Bose tag too...i couldn't get a mitsubishi tag but any help would be much appreciated
  • Bose Master
  • 5,126 Answers
I would have thought it will become obvious from the burnt parts and broken parts inside the amp, if it was struck by lighting, when you take the top off. But clearly unless it has an aerial connection, it will have to be from the mains lead that lighting went in to the unit, so a good look around the power supply section, I think first.
To be honest depending on the damage if you fix this one they should give you top marks!
Many service people would say no-chance!
Posted on Feb 06, 2010
How to fix a 73 in mitsubishi tv that was struck by lightning?
You will need to take this to a repair center. Expect it to be un-repairable.
Aug 03, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Can't listen to TV without hooking it up to stereo speakers. How to fix? Mitsubishi CS 26301
first of all you have to be sure that the speakers are on.To find out you should go to the main menu and select audio for the speakers status.
Dec 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Denon receiver just struck by lightning.
Any time a unit is hit by lightning, it is usually a total loss. While the initial problem may be fixable, other components have been stressed and are likely to fail. Most shops won't work on these units because of the likelyhood of continual failures. Warranties won't be given or the repairs. In your specific case, the switching IC has been damaged and needs to be replaced as well as the surround processing section. This is best handled as an insurance claim for replacement.
Dan
Apr 06, 2010 | Denon AVR-1905 Receiver
Mitsubishi medallion 65", the audio works sometimes the stops working
I believe that you mean "the audio works sometimes then stops working" If that is correct one of two things is happening. If this is on one channel it could be that the unit is set to SAP and should be set to stereo. Go to the menu and check the settings. Change to stereo if necessary. The other possibility could be that you have bad solder joints in the audio section. If you can solder you can probably fix this. Otherwise call an experienced tech to fix it. Let me know how you make out.
hardrocko
Feb 10, 2010 | Mitsubishi WS-65809 65" Rear Projection...
My tv was struck by ligthning how do i fix it?
fixing the tv after a lightning strike is a higly specialized task, you have to deliver it to a qualified tv technician ,there is nothing you can do yourself to fix it
Jan 26, 2010 | Televison & Video
I have a 58'' HP Pavillion Projection screen TV. It was struck by lightning. the power cord is good. It will not turn on at all, no fans running, etc. What do you think I will have to fix?
As u have just said that it was struck by lightning the only way to get the TV back working is to replace burnt items on the moterboard .becouse lightning must have demaged some components on the power supply, if possible i would preffer a new power supply board
Aug 31, 2009 | Televison & Video
Tv struck by lightning
You wont be able to fix the TV your self as the power circuit board may have blown - consult a qualified repair man. Buying a surge protector for your expensive electronic goods is highly recommended.
Jul 10, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Mitxubishi WS-48311
yes !! probably need to replace some parts in the POWER SUPPLY area, starting with the main fuse , or the whole POWER SUPPLY unit may need to be replace . hope this helps
Apr 26, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Bose 901 VI Main / Stereo Speaker Logo
372 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
