ViewSonic VE155 flat screen monitor I have 6 of these monitors which are used heavily in my office. They have serviced me fine for 6+ years. However, one by one they seem to be generating the same problem. If the screen is not in use, it could be as short as 4 minutes and the screen goes dark into sleep mode -- when I touch the keyboard or mouse, the screen comes back up and is "bleeched out" -- you can still see the program images but they are 'white-ish' almost like a blanched x-ray. Anyway, if I turn the monitor on and off by the button on the front of the screen, this image does not change. If I unplug the screen and re-plug it in, the image is perfect again. The perfect image will last the whole day if you are active with the computer.... If you step away for a few minutes and the screen goes dark, there is a chance the blanched screen will reoccur(it is not consistent - sometimes it will come back up just fine). Re-booting the computer with the blanched screen does not help. Is this correctable? It seems a waste to get rid of all these screens that otherwise work so fine. Thank you, Dave Stevens
  • 4,281 Answers
Also make sure graphic driver works fine.
Go to display property and disable hibernate also set turn off monitor settings to never in power schemes then apply and ok.
Uninstall graphic driver then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 05, 2010
I have a Viewsonic VE155 monitor and cannot get the contrast and brightness off my screen how do I get it off? it just started happening
Check to see if you can reset the electronics of the monitor to factory defaults. If no reset button contact viewsonic for a hidden code to accomplish same. If no results then your monitor is a sick puppy. Just to make sure plugh in another known working monitor to make sure that it is the monitor and not your computer.
Sep 19, 2017 | ViewSonic Computers & Internet
Viewsonic ve155
INVEST IN A NEW MONITOR,IF OLD.
OR USE YOUR WARRANTY IF ANY.
Jun 19, 2013 | Computers & Internet
Back light doesn't work. the backlight is automaticlly turning off in 2 seconds after i press the power button but lcd stays on. i checked and re-checked all capacitors and all fuses and relay's all thouse...
You need to test the lamps or use test lamp to verify that the inverter circuits are working or not. Do get 12vdc at the inverter circuits? I do not think it has realy in this monitor, so is it the VE155 or some other brand?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Nov 29, 2010 | ViewSonic VE155b 15" LCD Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Viewsonic VX2235wm Horizontal Image Problem
Tricky one. Have you tried using different dispay resolutions from your Windows Display Control Panel?
ie 1200x1014, 1600x1400, etc.
When you say you used the manual adjust, do you mean the horizontal sync option?
Did you perform a Settings Recall?
And most monitors have a way of entering into an engineering "Factory Service Menu". Usually by depressing specific buttons while the monitor is OFF, and then pressing the power button while still holding the others. Then let all button go at once. From there, hit the normal button that you use for getting into the OSD. In the OSD, there's usually a new field with all kinds of cool new settings to play with. One of them being a soft reset. You'll have to search the net for how to enter into your Factory service menu.
Oh wait! I know!
If your picture has moved to the right, move yourself accordingly.
So that now you and your picture will be aligned properly.
He he he...
Kidding!
That one was from ViewSonic customer support.
Apr 03, 2009 | ViewSonic VX2235wm LCD Monitor
My viewsonic monitor is not working
Considering the price of monitors versus the cost of repair. It would cost less to replace the monitor.
Mar 12, 2009 | MPC Computers Viewsonic E771 17 in.CRT...
Monitor turns on and off
Is it an HP or a Viewsonic screen ?
Either way, looks like a power supply problem to me, some Viewsonic screens are known to have a problem with their inner power supply card, If your screen is still under warranty I suggest you don't lose time analysing the problem and just make them come and fix/replace it
Nov 06, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Viewsonic problem
Get the RMA, I had no problems whatsoever with thecustomer service folks. They answered email within 1 business day, shipped off the monitor last week...
Jun 22, 2008 | ViewSonic VX922 19" Monitor Flat Panel
VA720
You could possibly have 2 problems with your monitor, though they are more then likely linked.
The Viewsonic monitors (like most) end up with buldging capacitors after several years use. This is typical of most equipment these days.
You can either replace the capacitors yourself or get in contact with someone local to you to have it done.
The reason I say there could be 2 problems that are linked is the fact when your screen does finally come on, it flicks the screen up for a second which would normally indicate a problem in the inverter circuit.
Because of the power fault though I believe it is more likely the one fault causing two problems.
With the capacitors failing, the voltage inside that powers the internal video board are not stable. That is what causes it to behave as it is.
On the homepage of this site you can use the Repair Service section (on the left side about half way down the page) to find a local repairman if that is the route you want to go.
Apr 19, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VX922 monitor - black screen - green power light flashes
PLEASE read Carefully so here is a fix for the green blinking light ...the monitor is going into shutdown....protect mode......THIS is ...Only for the seasoned electronic service tech ......YOU NEED TO BE into Electronics ..or have electronic background and know how to solder to do this........I been doing repairs for 30 years now ..............After extencive troubleshooting and replaceing a lot of electrolitic caps on the inverter board and spending about 10 hours doing so ....i decided to eather go for broke and blow this up more or trash the unit......................Well my blinking light deal went away...my monitor you could see it trying to start and just shut down............first of all make sure you have no broken solder work on the inverter board or swelled up caps ...Thay use lead free solder so the solder work sucks also...........I did pull the main buss line from the inverter pc board that runs the transformers to test to see where the trouble is.....found its at the high voltage end of the inverter board and The viewsonic 922 uses a protection ic on the inverter board and it tells the controll ic whats the High voltage status of the inverters.....I soldered a 47uf @ 25 volt cap on pins 7&8 of ic-u2 [ bi3101a ] Pin 7 is posivtive pin 8 negative of the cap.... and then soldered pins 10 and 11 togeather on the other side of the ic.......ITs fooling that ic telling the main controll / protect line thats all is well........I would guess the whole deal is LOW inverter voltage or maybe a surface mount device thats going to go........could be low resistor tolerence also............The monitor been working for a week now.........Always on.....anyways........YOUR problem may just be bad solder or bad caps...........if you Have a electronic background or have a friend that works on electronics have him look at the caps.see if any or swelled or rounded on the top of the caps..Also chect the main plug that goes to the LCD backplane to make sure its in correctley................if all that checks then the problem is ON THE INVERTER BOARD ONLY ......befor doing what i have done......I also have a Viewsonic VA-800 that had some of the same problems also ,but it had a lot of lines on the video.......I replaced the,,,,, 2.2 mic @ 50 volt cap in the middle of the main board on it and its still running.....but has about 3/8 of white traces following all the words on the desktop...[[[ anyone that knows this fix i would like to hear from ]]] ..........NOTE if you dont know about electronics...dont attemp any of this......their is a lot of voltage on the inverter board........my answer is that these monitors are JUNK...poorley built units.....
Jan 18, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
