Question about Brother HL 5250DN Laser Printer
My brother hl5250dn laser printer won't feed paper. all seems okay other than that.
    President:
  • 2,306 Answers
Make sure the paper guide at the rear of the tray is not set too tight, it needs to be right on the mark for the size you are using. After that you can clean the rubber roller above where the paper sits with a towel damp with alcohol. If it still doesn't feed you may need a shop to check the roller drive gears and clutches.
Posted on Feb 05, 2010
5890cn manuals part and assembly
Go on free manuals sites , I have a few of them, and you can download manuals for virtually everything you have even things you get at goodwill.
Oct 04, 2014 | Brother Lower Paper Tray Feeder / Tray for...
Paper tray doesn't raise on my brothers hl5250dn printer. Says papertray empty
I have had the same exact problem; make absolutely sure that the exit chute is seating properly. With the exit chute open (as if to clear a paper jam) actuate the white spring loaded clips that hold the exit chute, mine were not traveling to their full extension and by moving them a few times this resolved and the exit chute was held more firmly and the rollers spin the right direction.
Jan 30, 2011 | Brother Lower Paper Tray Feeder / Tray for...
MFC-9840CDW Laser Printer: I have a Brother MFC-9840CDW laser printer it is o...
Wipe the paper feed rollers with a clean rag wetted with plain water. You can also replace the feed rollers, search for "paper feeding kit" for this printer. Should be $20 to $30.
May 18, 2010 | Brother MFC-9840CDW Laser Printer
Hi - I have a Brother HL5250DN with the paper light flashing but there is paper in the tray and now it wont print - can you help??
Is the Status light also red? This could mean other things than being out of paper. It could be a paper jam (most commonly anyway). Get a flashlight out and inspect it for jams.
Jan 13, 2010 | Brother HL 5250DN Laser Printer
Frequent Paper Jams in Brother HL-2140
Every 120,000 pages, the paper feed rollers, fuser, transfer roller, and OPC belt cartridge should be replaced, usually by a trained techncian.
Fuser and OPC belt units are customer-replacable.
The multiple feeding of the paper into the printer is due to a worn paper separation pad. part no. LM0711001. If the machine is picking up the paper okay and the jams occur solely from multiple sheet feeding, then this part is probably all you will need. The steps required to access and remove & replace the separation pad unfortunately is about 10 steps. Better consult a tech.
Oct 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Drum and error light are on - got new cartridge - installed as directed - blue light will not stay on - printer will not print - red and orange lights will not go out
I can't recall the buttons on Brother laser printers but leaving the cartridge door open and pressing and holding down one of the buttons for about 5 seconds will clear the drum light error.
I've done this to clear the same error on aBrother HL5250DN laser printer.
If this doesn't work please post your printer's model number.
Sep 21, 2009 | Brother HL 5250DN Laser Printer
Brother hl5250dn laserprinter problem due to no impression.
unistall the printer driver and reinstall it or cheak it,s ink cartrage
Aug 22, 2009 | Brother HL 5250DN Laser Printer
Brother hl5250dn printer making noise during paper picking
check the rear end of the paper tray. There is an adjustable bar for paper size that is probably not locking into place. If this moves accidently when refilling the paper tray. it may cause a rather unnerving noise. You need to adjust this bar to fit snugly with the short edge of the paper stack.
Apr 15, 2009 | Brother HL 5250DN Laser Printer
Paper Light Blinking
make sure the rear part of your paper tray is not pressed too tightly against rear of paper. it will prevent the paper from raising up fully to the feed roller. you can also try cleaning the feed roller if that doesn't do it.
hth,
razors
Feb 05, 2009 | Brother HL 5250DN Laser Printer
Brother HL-2040 Laser Printer Paper jam
Most likely something has broken in the loading gear. Never pull paper against the normal flow, of course, you know that now. Unless you can locate the broken part and replace it, I'm afraid there's not much you can do other than manually feed the paper.
Dec 31, 2008 | Brother HL-2040 Laser Printer
Brother HL 5250DN Laser Printer Logo
598 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
