Question about Philips DVDR70 DVD Recorder
Philips DVD Recorder
Hello, I have a Philips DVD Recorder that will not record. It goes through the motion of starting up and after a few seconds freezes. After pressing stop it takes a while till the machine will open the tray but it then says the Disk is empty. Any idea what is wrong and how much it may cost to repair.
I may be a bit late but I just upgraded my firmware. I downloaded the zip file and burned it as per the instructions with Nero Burning Rom. This may help. Visit the Philips website and search for your Dvd recorder there.
Posted on Jul 10, 2008
  • 476 Answers
Sounds like the DVD writer is faulty. With it being an older model the cost of parts outweigh the value of the player.
You can buy a replacement DVDR3380 or DVD3480 cheaply at www.cheapestelectrical.co.uk
Posted on Feb 22, 2008
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I record sports events on my dvd recorder on slp 6 hrs and when i rewatch the screen goes blurry when the action starts
SLP is the lowest picture quality possible for a DVD recording. Due to the extreme compression used for this mode, fast motion and detail are lost. It's one of the costs of long playing time. Try the next recording speed faster?
Apr 02, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
Notes:
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Apr 28, 2009 | Philips DVDR7260H DVD Recorder / HDD...
Magnavox MDV630R1/17 DVD Recorder problem
Unlikely, but good possibility. Investing in a head cleaner would not be a bad idea. But also make sure the unit is well ventelated.
Dec 10, 2008 | Philips MDV630R DVD Recorder
Unable to view recorder movie
unplug 10 min then try from start...somtimes they freeze up!
Dec 09, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips MRV700VR DVD Recorder / VCR Combo
Crack the top open and look inside for any foreign matter. Usually the cause is debris in the IR path that detects start and end of tape or the loading mechanisim is faulty.
Sep 24, 2008 | Philips MRV700VR DVD Recorder/VCR
DVD Recorder
double check the firmware from philips website, but most likely that hard drive has an internal problem
Aug 24, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Picture/Sound freezes
This model does NOT work well with HD boxes. I would double-check the Philips website, and upgrade the firmware for device since all 3 players were doing same thing.
Aug 13, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Problem Recording HDD to DVD-R
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Jan 16, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Philips DVDR70 DVD Recorder Logo
231 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
