Question about Pioneer VSX-1015 Receiver
When turned on amp shuts down and displays power off. what may be the cause?
  • 1,476 Answers
You have a short in your unit somewhere which is triggering the fault circuit. It could be almost anywhere but more than likely it is an output driver transistor. If they all check OK I would troubleshoot the power supply. Do you get any fault indications on the display? Let me know and I'll see if I can narrow down the search.
hardrocko
Posted on Feb 05, 2010
TV shutting down, lamp and power light blinking
I would try a new lamp. Lamps have varying qualities & usage conditions may cause varying life spans.So, even though the lamp may be 1 year old I would try a new one first.
Jan 07, 2015 | Samsung HL61A650C Television
Tip
My Pioneer displays Overload
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
on Jun 22, 2009 | Pioneer VSX-D608 Receiver
Kenwood kdc-mp142 why does it shut down when
Have you checked your speaker wiring as it could be you have some wires crossed ie: negative feeding the positive side causing the shut down & check the Ohms if at high volume you are trying to drag to many Ohms it will also cause the built in amp to shut down to protect the system dont keep incresing the volume as the strain will do damage
Sep 18, 2014 | Car Audio & Video
Gigrac 600 turns off, displays the Amp 2 clip light then turns off. All volume knobs are turned down. All external items are disconnected and it still turns off. My only complaint about these units is...
There is a bad amp in that divice that is causing an overload. The device then shuts down. This is not something that you can fix yourself. IT requires special diagnostic tools and troubleshooting as well as soldering ability.
Aug 17, 2013 | Soundcraft Gigrac 600 Powered Mixer
On my Compaq Presario 2100US my screen has started going black intermittently while running. I then have to power it down using the power button because I can't see the screen to shut it down properly. ...
  1. Remove the battery & switch on the PC in AC mode.
  2. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  3. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
  4. If still no display, connect an external monitor, check if display is comming.
  5. If Display is coming then your LCD need to replace.
Aug 20, 2010 | HP Compaq Presario 2100US Notebook
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
2006 tahoe with heated seats. when the seat is
The heating element in the seat may be failing, even thogh it heats the seat, the element could be causing the circut to spike upon power shut down. Relay takes mili-second to shut down after ignition kill and power feed comes direct from battery. Check amp. draw at switch of bad seat and good seat upon shut down. If bad seat higher that 5 amp difference element n/g. Also check for bad relay as they can short internal and cause problems if primary power cut before switch shut down.
Jan 30, 2010 | 2003 GMC Sierra 1500
Copier power outage while in operation caused paper jam and shut operation down. Service icon activated and will not go out.
Hello sir; Try to do a reset, open clamshell and remove top front cover, close clamshell and reconnect cable from cover to DC controller. turn on power and then short pins JP101 & JP102, the display will show out "F" release the short, then put everything back turn on the power.
Oct 20, 2009 | Canon PC-940 Black and White Copier
Amp lights up (display) and then fails to switch
You need to replace the power amp transistor or mosfet. Bring to electronic technician for repair.
Jul 24, 2009 | Sony STR-DE998 7.1 Channels Receiver
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
Open Questions:
Calibration: low volume, power of all channels is decreased I have the following setup: AV Receiver: Pioneer VSX-1015 Front: 2 x Infinity Alpha 40 Center: 1 x Infinity Alpha Center Surround: 2 x Infinity Alpha 30 Surround back: 2 x Infinity Alpha 20 Subwoofer: 1 x Harman Kardon HKTS200SUB Receiver is new, speakers are used but in good condition, subwoofer is new. ---------- I followed the calibration proces with the microphone. Sound: excelent quality of sound. Never heard anything like this. Good bass, pure and lifelike sounds. Plays loud enough to bother the neighbours. Much bass from the speakers while subwoofer only produces a little bit of ultralow, feelable but not hearable vibrations. ----------- So far so good. Although the sound volume is loud enough for me, it really doesn't reach te output power as pioneer subscribes. In order to play loud I have to turn the volume to almost max. Compared to an old sony receiver (5 x 100 watt rms at 8 ohms 0.07%), the outputted power seems to be much lower. I reach te same (feeling of) power when I turn the pioneer to 80% volume where the old sony reaches that feeling yet at 20% volume. ----------- I noticed that the calibration process decreased the output level of all speakers. With the subwoofer on max (button on the subwoofer itself), I get the following levels: front: -8.0 db / -9.0 db center: -5.5 db surround: -8.5 / -9.0 db surround back: -7.5 db / -7.0 db subwoofer: -10.0 db (MAX decrement!!) All speakers are auto rated as LARGE as they all can deliver good bass. The equaliser has decreased the low frequenties of all speakers and increased the high frequenties. ---------- I tried to manualy increase the output level of the channels. Outputted power increases a lot but doesn't much good for sound quality. I also tried the calibration proces with the sub at half power. Now the sub level is only decreased by 2.5 db and allother speakers are decreased with 2 db less, so a little bit less decrement but stil decreased. ---------- question I have read that increasing the power times 2, puts an extra 3 db to the sound pressure. Watching the heavily decreased db levels on each channel, sounds to me that the receiver works at relatively low power. 7 x 35 watt or whatever... ? Can it be that the subwoofer is too large for this system as it is decremented with the max 10 db? That the system cannot decrease the subwoofer any further so it is going to decrease the speakers? But if that is the case, wouldn't it be more logic that the speakers are incremented and the sub is decremented in level? What about the sound quality? Can it be that the pioneer receiver also measures distortion of the sound? The room where the speakers are in is a small room (20 square meter). Can it be that the receiver decrements all levels in order to reach the highest sound quality? --------- The reason I want to know is because I want to understand the calibration. I am fully satisfied by the sound quality but knowing there might be more in it, is not a good feeling ;-) Thanks a lot!!
Aug 08, 2013 | Pioneer VSX-1015 Receiver
See all Pioneer VSX-1015 Receiver Questions
Pioneer VSX-1015 Receiver Logo
175 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
