Trying to find and replace the forever running battery. The clock ect one.Then reset my system password. Can't get the old one to work and lost my product key for XP home.
  • Robspad@hotmail.com Feb 05, 2010
    Bios passord and then I have to find my product key for XP home. A virus demands I reinstall XP. Tag is missing when I pawned it. Hmmm? Thief!
    Good so far.
  • 4,472 Answers
I assume you are talking about a computer. You will find the battery on the motherboard. Now as for the password you can't remember is this the bios password or the windows login password? Removing the battery won't help if its your windows password you need. If that is the case you have a couple options. Do you have another administrator account created in windows? If not then you will want to consider backing up any needed files by plugging in the hard drive to a usb adapter or another computer, then after backing up any needed files reformat and reinstall windows.
Thank you,
Lee
Posted on Feb 05, 2010
1997 Mitsubishi Montero sport, dont have the cover for my fuses and I need to know which is the "ECU" fuse to try resetting my computer.
Often disconnecting the main battery for say 5 mins should do the trick without needing to find the fuse.
May 17, 2015 | 1997 Mitsubishi Montero Sport
Please enable me to log on before i get lost forever in cybersaceri
LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usual be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware sestets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
Apr 29, 2014 | Computers & Internet
Reset cmos
Modern computers use a BIOS not CMOS. Regardless of what we call it, if you can enter the BIOS by pressing the F2 key (could be a different key, check manual) there should be a choice to restore defaults. If you cannot get into the BIOS then usually just removing the small silver coin battery from the motherboard for 10-seconds and reinstalling it will reset the BIOS and your clock (which is how you will know it has been reset.)
If you are trying to reset the system because of a lost BIOS/Low Level password, take note that these passwords are often stored in a special microchip on the motherboard and often require a new logic board be installed to resolve the issue. Manufacturers protect the BIOS passwords to help protect user information and to reduce the value of stolen computers.
Jan 04, 2014 | Toshiba Satellite L840-BT2N22 Customizable...
I am getting the following message: 0250: System battery is a dead-Replace and Run set-up 0270: Real time clock error I am trying to run set but I am not getting any result.
In that case replace the Cmos battery, usually underneath the keyboard, and enter the BIOS to reset the clock. Select default settings in the menu.
Hope that helps.
Jan 03, 2011 | IBM ThinkPad R30 2656 Notebook
Need to flash the bios to get the password off guy who gave me the comp is out of contact an vista install failed trying to boot from cd but password comes up at bios entry an boot menu
You cannot remove the password by flashing the bios. However, there are two possibilities that _might_ work, depending on how that particular model works:
1. Unplug the computer and remove the internal clock battery for a few hours at least - maybe overnight
2. Some motherboards have a "CMOS Reset" jumper on them that you can use to reset any password in the BIOS (and any other BIOS settings). It will probably be a two position jumper on the motherboard, usually somewhere near the clock battery. Put the jumper on the opposite position that it is in, power up the computer for about 30 seconds, power off the computer, then replace the jumper back to it's original spot. Then boot up the computer normally and you should be able to go into the BIOS
These two options don't apply to all systems, but probably most of them. IBMs are an exception because they store the BIOS passwords encrypted in a memory chip that doesn't require battery backup, so on them there is no way to reset the password. Hopefully yours is not like that and one of the solutions I gave will work.
Dec 18, 2010 | Acer Aspire™ T180 PC Desktop
Advance 10F+ Motherboard battery
The Battery needs to be replaced, However replacing it will reset everything. All of your BIOS Settings, Time ect. However there is a rumor that i have only found to be true on few systems, if it is left plugged in your bios settings will not be lost. but... since your loosing time with it plugged in. Im thinking its gonna loose them no matter what.
Apr 14, 2010 | QDI Group QDI Advance 10T Motherboard
I have several 600's and they all have the same issue. They are giving 161 192 163 errors. I replaced the battery in them and then go to try and setup the time. However, instead of letting me set the...
161 = CMOS configuration lost (battery has died).
163 = CMOS error; Clock is not updating.
192 = System fan is faulty, not plugged into the system board or the system board itself is faulty.
Whe you replaced the RTC (real time clock/BIOS battery) did you make sure that the CPU fan was working?
If it is then go back into the BIOS and reset it to defaults. Save the changes and reboot, then go back into the BIOS and try to set the time and date.
Regards.
Feb 22, 2010 | IBM ThinkPad 600 Notebook
Forgot password... how do i unlock it
This password recovery software will help you get things done and reset your forgotten Windows Admin passowrd easily. It is capable of resetting Windows Administrator login password, and recovering lost password for multiple web browsers, mail clients, FTP clients, chat messengers etc. Moreover, it can find those lost software license key or product serial numbers. Good luck.
Dec 24, 2009 | Microsoft Windows Vista Ultimate Edition
How to remove power on password on hp compaqnx6110?
You can try reseating the RTC battery:
http://h20464.www2.hp.com/index.html
Real-time clock battery removal Before you begin: Remove the battery and keyboard.
  1. Disconnect the RTC battery cable from the system board
  2. Use a small, flat-bladed, non-conductive tool to flip the RTC battery out of the socket on the top cover.
Real-time clock battery replacement
  1. With the positive (+) side facing up, insert and press the RTC battery into the socket on the top cover.
  2. Reconnect the RTC battery cable to the system board.
If this does not fix the issue, you may have to replace System board
Jul 06, 2009 | HP Compaq nx6110 Notebook
15 people viewed this question
k24674
jasbo
jasbo
