Question about PfaFF Tiptronic 2040
Threading the machine
I borrowed a Pfaff tiptronic 2020 with no manual> How do I thread the machine?
  • 2 more comments
  • Anonymous May 11, 2008
    i didnt realy understand how to thread my tipronic 2020 please try to explain it a little better i am not too good with that, thanjk you
  • sylviad May 13, 2008
    I asked this question 3 months ago, and I had borrowed the machine for the weekend! So ...the answer is a little late.
  • Anonymous Sep 15, 2008
    threading machine
  • Anonymous Mar 22, 2014
    I forgot how to thread my machine
What is the setting to hem
Posted on May 12, 2008
It adjusts the needle plate position front to back.
Mar 25, 2016 | PfaFF Sewing Machines
I paid to have my Pfaff tiptronic 2020 cleaned and repaired back in April. Haven't touched it till now. Although their test fabric looks fine with threads doing what they're supposed to, it doesn't work...
Rethread your machine. More than likely it is your bobbin threading is not in the guides right. When you rethread pull on both threads to make sure everything is seated in the guides right. Study your machine manual carefully.
Sep 18, 2017 | Sewing Machines
Pfaff tiptronic 2020 locking up/cutting bobbin thread
try changing the needle
when sewing a project-- the needle & fabric & thread must be compatable
check to see if there is any burrs on the needle plate or on the bobbin case
always make sure every thread guide is used
make sure the bobbin is inserted correctly in the bobbin case
Mar 31, 2012 | Sewing Machines
How do i fix the tension on my pfaff tiptronic 2020
It sounds like you need to adjust the bobbin tension. There is a small screw on the bobbin case to tighten/loosen the thread's tension coming out of the case. Refer to the user manual on the procedure to set it.
Nov 28, 2011 | PfaFF Tiptronic 2040
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Sewing Machines Logo
594 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
