Question about LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher
I have a brand new LG dishwasher-LDF6920ST. I
I have a brand new LG dishwasher-LDF6920ST. I find that the detergent is not dissolving. I either find it in a hardened block after the cycle or I find the detergent just spilled in the bottom.
  • 375 Answers
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Posted on Sep 11, 2010
What brand of detergent should i use
I have had good luck with the powdered dishwasher detergent from Wall Mart's brand Great Value.
Before I switched to this brand I had to clean the washer drawer several times because the detergent I was using was not dissolving properly and would leave a residue in the bottom of the drawer and on the dishes.
Aug 23, 2013 | Fisher and Paykel DD605SS Stainless Steel...
My dishes come out with a gritty sand all over them.
If you live in an area with hard water, the grit is probably hard water deposits. Dishwasher detergents no longer contain phosphate, so the detergents often leave behind hard water deposits on your dishes. There is a great solution at www.cloudydishes.com
Oct 15, 2012 | LG LDF6920ST Stainless Steel 24 in....
Have a brand new LG dishwasher, food residue still left on dishes after cycle. I am not talking about unusually dirty dishes here, just normal tiny bits of food. This is why we bought a new one, old one...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Aug 06, 2010 | LG LDF6920ST Stainless Steel 24 in....
D/w doesn't dissolve deterg. & therefore not washing dishes
Do this test:
-Upgrade to a name brand detergent like Cascade or Electrosol.
-Do not over fill the dispenser cup
-Do not place large items near the door/near the dispenser cup.
-Make certain that both spray arms can spin freely after you load the dishwasher but before you close the door to begin the wash.
Please report back what you find, OK?
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
The dishwasher dispenser tab did not dissolve.
That could have definitely lowered the water pressure enough to slow down the filling of the dishwasher... maybe it was just a fluke. If it keeps happening, you might have to dig deeper to find the gunk...
A Google search for the part number turned up this... the diagram on page 8 shows the parts you will need to inspect... parts 66, 64, and down in the bottom of 14 is where the gunk will collect.
Dec 04, 2009 | Frigidaire Dishwashers
Automatic dishwashing detergent granules do not dissolve
Did you switch brands of detergent?
You mentioned that the diswasher is old can you check the nozels of the wands to see any of them are plugged near the ends this will affect wheather the water is reaching the door.
Hope this helps
Al
Sep 11, 2009 | KitchenAid Dishwashers
Dishwasher detergent won't dissolve
Recommend you stop using the gel and switch to a brand name powder - like Electrosol or Cascade. Never use gel, gel packs or tablets in any dishwasher. Avoid untra-cheap, generic powders.
If problems continue, a service call, with them checking that the heating element is working is the follow up step.
Good Luck!
Apr 02, 2009 | Whirlpool DU930PWSS Stainless Steel...
LG LDF6920ST Bottom spray arm dose not work
The LG LDF6920 dishwasher has an innovative "Vario" motor/check valve. It switches between full power spray on the upper arms and the lower arm. So, if you are looking inside the dishwasher to see which arm is spinning, you just have not opened it when the lower arm is turning.
if the root problem is that your dishes are not getting clean with this water conserving DW, go out and buy a name brand detergent powder - like Electrosol or Cascade. And use less powder then you have been using.
Good Luck!
Feb 02, 2009 | LG LDF6920ST Stainless Steel 24 in....
RESIDUE ON DISHES-NOT CLEANING WELL-DETERGENT NOT DISSOLVING-LONG CYCLES
Sounds like you have motor pump problem and may need to be replaced.  The parts are covered for 2 years but you'll have to pay for the labor.  Call a qualified LG technician for service on your dishwasher.  You can find them on the LG website.
Apr 13, 2008 | LG LDF6810 Built-in Dishwasher
LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher Logo
490 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
