Question about Toshiba Televison & Video
The vcr deck will not open. it clicks but does not move. the dvd side works. this is a reconditioned unit
    Sergeant:
    Champion:
  • 271 Answers
It could be alignment, belt, Motor, gear or a motor driver IC.
Posted on Feb 05, 2010
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
Samsung SV-DVD545 dvd / vcr combi unit cuts off after switch on
i would guess your vcr is not powered off completely preventing the dvd from playing
May 15, 2012 | Televison & Video
My liteon vcr/dvd recorder lvc-9016G: The DVD keeps showing "invalid disc" when I know they are not. I bought it in Sept.07 and it was OK till now. The VCR is working and recording. Is the...
You have 2 choices here, you can either submit the unit to an authorised service centre (or similar), obtain a quote on the likely cause(s) of the problem (which to me sounds like the digital control circuit has failed partially to the DVD deck and/or corrupt firmware which is not possible to upgrade), the potential costs involved, and so on, you can then make a decision based on the unit's age and overall condition as to whether it's economical to repair or not. The point is, the unit is repairable, but it could prove expensive.
The other option you have, is to keep the unit as a VCR (which is cheaper than repair to the DVD), and later on, buy a new DVD player/recorder (as required). The cost of the repairs to your existing unit vs. buying a new one could be significant. Up to you.
Personally, does the DVD deck play any shop-bought movies? If not, don't bother getting it repaired. Buy a new unit (but keep your existing unit as a VCR while it works).
Apr 18, 2011 | Lite On LVC-9016G DVD Recorder/VCR
Have a samsung DVD-V1000 VCR/DVD combo unit. DVD player works fine. been experiencing gradual decline of the VCR and now it won't play at all. will **** tape into the machine but can't get it out. any...
Always frustrating when a videotape gets stuck in a failing/failed VCR deck. Since all decks use a loading motor and gear system, it would be a simple matter of gaining access to the terminal pins of the loading motor (assuming you can see these from the top of the deck) and applying 9V DC voltage to 'unwind' the loading mechanism - you may get a little bit of tape outside of the cassette, but at least it's ejected. If the DVD deck works as you say, you may be able to continue using this for a while.
If the loading assembly is toward the underside of the main deck, you may need to remove the entire VCR mechanism - then you can apply the 9V to the motor to unwind the gear (it is easier to apply a low voltage to the deck rather than use physical force to unwind gears - as you may damage them) - while leaving the DVD deck in the unit untouched. There should be 2 separate mechanisms in this combo - 1 being for DVD the other being for VCR - as long as you are careful when removing the VCR deck, you should have no problem retrieving your tape (with maybe a little creasing but otherwise undamaged) from it. Be careful when removing the top cover and front panel assembly; you don't want anything broken.
Since VCRs are becoming obsolete these days, it is hardly worth getting this one repaired by any service centre (unless you want to pay a fortune, which is usually more than the retail price of a new combo unit). It's up to you.
NOTE: you cannot operate this unit with the VCR deck disconnected from the motherboard (you will get an annoying error display with the VCR removed). Once you have successfully removed your tape from it, reconnect the VCR mechanism to the board - but do not use it - just use the DVD part if that is still OK. Refit the covers, plug machine into power. Done!
You need a lot of patience to undertake the abovementioned action. Fingers crossed.
Mar 28, 2011 | Samsung DVD-V1000 DVD Player/VCR
Dvd player stopped working
NEED REPLACED DVD MECHANISM UNIT
Manufacturer Panasonic Part Number LSXK0118 Description MECHANISM
Sep 12, 2009 | Panasonic Televison & Video
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Samsung DVD-VR375 says "load" but tray for DVD/VCR won't open
I think you have problem in DVD deck assembly the owner manual won't help you if still under warranty bring back to Samsung if out of warranty you can buy the DVD deck from Samsung and replace by yourself
Let me know if you need part number for the DVD deck
Dec 04, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
VCR portion not working found Damaged Components
Ya rca needs to recall all rca drc8335[tape decks]
I unpluged power to deck [jumper p/s to deck]
use a other vhs deck pluged in avi port
Aug 14, 2008 | RCA DRC8335
No power to DVD combo player. VCR OK.
The power circuit for the DVD and the vcr are separate look for a open diode and transistor in the circuit that supply the DVD.GOOD LUCK.
Apr 26, 2007 | GoVideo Go Video DVD/VCR Combo
Televison & Video Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
