Question about Lexmark X5470 All-In-One InkJet Printer
Paper will not feed into printer, even with hand pushing on paper. rollers do not grab the paper.
  • Official Brand Answer
  • 3,344 Answers
The problem could be an object inside the Auto document feeder that could be blocking the path of the paper or preventing the feed roller from feeding the paper. You can try the following, Turn off the printer, unplug it from the power cord, then remove the paper and then turn the printer upside down and shake it a little bit, sometimes this will help remove any objects inside the printer.
Posted on Feb 09, 2010
Error paper jam
Hello Cassandra,
It sounds like you are having phantom paper jams. When the printer starts a print job and tries to pull a piece of paper but can't grab it the printer thinks there is a jam but there really is not. If the paper pickup rollers are worn down they are not able to grab the paper correctly to feed it into the printer which causes this type of error. The rollers are considered user installable and come in a kit with the rollers and the paper separation pad which keeps more than one paper from being pickup up at the same time. Installing the paper feed kit should clear up your paper feed problems. The paper feed kit is available here: http://www.ccl-la.com/catalog/product_info.php?products_id=342
I hope this helps.
BuddyMc
Aug 06, 2013 | HP CP3525N Color LaserJet Printer
Paper won't feed properly and jams. the paper starts to feed then twists and jams.
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
My printer will not grab the paper
I have an R2400 and it is very finicky about grabbing the paper. I have to hand feed sheets of thick matte paper one at a time with just the right amount of pressure and even then sometimes it takes two tries. Make sure you keep the rollers very clean.
May 04, 2010 | Epson Stylus Photo R220 InkJet Printer
The automatic document feeder doesn't grab the paper unles the sheet of paper is pushed. Even then, feeding doesn't work well. Can you help?
Generally, you could clean the document feed rollers with WD-40, or a platen cleaner, but better yet, you should replace the pads and feed roller and I think you could do it yourself with my roller kit:
Roller ***'y,ADF Pick-Up,M1522n/nf/M2727/CM2320mfp
Part no. 5851-3580
Feb 17, 2010 | HP LaserJet 2727NFS All-In-One Printer
Won't feed paper to printer
Its printer feed roller problem. Roller needs cleaning . Clean all the roller using cotton moist with cleaning liquid eg. Petrol , Spirit or even Nail polish remover. Clean all rollers properly . It will resolve your issue.
Sep 03, 2009 | Canon PIXMA MP470 All-in-One Printer
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Lexmark Z25 Won't Feed Paper
Try cleaning the rollers with bar soap. just rub it on. I hope this helps! Please rate my answer.
Jan 01, 2009 | Lexmark JetPrinter Z25 InkJet Color...
Paper Feed Error
Your saying the printer grabs the paper on the one side more than the other?
Nov 13, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Paper won't feed
Pull out the paper tray and push the paper feed roller towards the machine. Try to turnaround the paper feed roller by hand. Reinsert the paper tray.
Nov 02, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon Pixma Paper feed not feeding!!
Either the pickup roller needs to be replaced,(a maintenance kit) or the tray isn't pushing the paper high enough to grab. Tyr loading a few more pages in the tray and making sure the tray is seated properly. Then try replacing the roller.
Sep 17, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
140 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
