Question about HP Designjet 4000ps InkJet Printer
I have an older printer a hp deskjet 845c series. It worked perfectly until I changed the ink cartridge. For some reason the red light on the paper icon keeps blinking and the printer no longer works. I have changed this cartridge many times with no problems. I tried reinstalling the printer, unplugged it to try and reset with no success. Can you help? Thanks!
    Champion:
  • HP Expert
  • 202 Answers
Pls first tell u hv clean then install the cairtage if so then pls check if u open the door cairtage comes mid position if so then problem due to inkif it doesn't so then this problem due to logic bord / caridge block it should be cross check by replacing one by one
Posted on Jul 17, 2010
    Genius:
  • 1,018 Answers
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Feb 05, 2010
All the lights on my hp 845c are flashing all at once and i can't print anything
that's indicate error code with ink cartridge, open upper cover ink cartridge must in the meddle, if so remove power replace the ink and clean encoder strip by wiping clean cloth. check also that ink docking / refilling station not yet full.
Mar 29, 2010 | HP DeskJet 845c Printer
My hp deskjet 845c won't print pink. I've tried two different ink cartridges and no pink ink. Is my printer probably on it's last leg? I have also tried cleaning the print heads...didn't help.
Are you using HP factory new cartridges?
If you are using third party or worse, refilled cartridges, that may well be the cause of your proiblems.
Don
Feb 24, 2010 | HP DeskJet 845c Printer
Red ink light blinking, won't feed paper. Have
this is hp security error, for ink cardtridge,(the ink cartridge has internal/acess counter), you need to try change cartridge, if contuinue send to hp service center
Nov 27, 2009 | HP DeskJet 940c InkJet Printer
It was suggested that I buy a new printer cartridge for my HP Deskjet 845c rather than use a refill, which causes the cartridge light to blink. I did go out and buy new cartridges for both color and black...
i dont know if anyone has logged this, but i would think that logically the lights would continue to blink until it detects the right amount of ink density and If they are chipped that the chip registers correctly. Ttry installing just one of the cartridges ( the cheaper one)
Jun 23, 2009 | HP DeskJet 845c Printer
Hp Deskjet 845c printer's cartridge light blinks constantly.
It probably has, the printer might not detect your cartridges properly, try using new ones
Jun 22, 2009 | HP DeskJet 845c Printer
Hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Mar 09, 2009 | HP DeskJet 845c Printer
HP Deskjet Color 845C Printer - Black Cartridge Problem
hi,
try to clean the nozzle with clean cotton w/ alcohol i think your cartridge has getting clog..or maybe it's getting empty!
rey
Nov 02, 2008 | HP DeskJet 845c Printer
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
Hp Deskjet 845C - Yellow Colour not Printing
I found this post to work for me when yellow was not printing on my HP PSC750 after using 2 cartridges: "Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge."
Jan 31, 2008 | HP DeskJet 845c Printer
HP Designjet 4000ps InkJet Printer Logo
96 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
