Question about Montgomery Ward (223600UP) Heater
I have an old montgomery ward floor furnace that i think may need a gas valve for. pilot stays lit, but when you try to turn it on, it,the pilot goes out. mod# ng5762a ser#653a1
james3751
  • 614 Answers
SOURCE: how do i light the pilot on a ward floor furnace
You need a very kong wire and a kitchen match. Turn the knob on top to pilot and push down have your flame already down thru the pilot hole at the bottom of the inside of furnace. Hold for a few seconds and release knob trun to heat. This unit works on a power pile systm and generates milivolts from the flame. Rus
Posted on Dec 13, 2009
hotuna
  • 288 Answers
SOURCE: floor furnace
That is the control for the main gas valve. These old ones have a gas valve separate from the pilot. Also the regulator is separate unit. You have to turn these controls with a long rod, right?
Posted on Dec 28, 2007
  • 1214 Answers
SOURCE: pilot wont stay lit installed new gas valve and new thermocouple
Is this a standing pilot furnace, or electronic igniton?
If standing pilot, does the heater use a fan to blow air through the heat exchanger?
If the answer to those questions is yes, then check that the pilot orifice is not partially plugged and that there is a strong pilot blowing against the thermocouple. If there is, replace the thermocouple. If not, check the orifice again, and check that the inlet screen to the gas valve is not filled with gas line trash.
If the the pilot flame is good and it continues to go out, the thermocouple magnet in the gas valve may be weak. Replace the gas valve as to get just the magnet and coil is not easy.
Reply back any questions you may have.
Posted on Jan 28, 2009
  • 53 Answers
SOURCE: My coleman floor furnace will not stay on
Have the thermocouple replaced, ensure the pilot flame is blue - not yellow, yellow indicates blockage in pilot
Posted on Oct 08, 2009
heatman101
  • 43501 Answers
SOURCE: Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Posted on Nov 12, 2009
Why doesn't the pilot stay lit?
Why Does My Gas Furnace Pilot Light Keep Going Out?
santafeair.com/blog/.../why-does-my-gas-furnace-pilot-light-keep-going-...
Jan 10, 2014 - The thermocouple is the copper rod you see the pilot flame hitting. It's a safety device that controls a small valve to shut off gas going to the pilot ...
Aug 11, 2015 | Kitchen Ranges
Where can we get a thermo coupler for a floor furnace Ward Model 570EDR.
Most floor furnaces use the millivolt gas valve and need a pilot generator to operate correctly. These generators are bit more than a standard thermocouple.
Ebay has one for less than $20
Apr 26, 2011 | Heating & Cooling
We are having difficulty lighting the pilot light on our wards gas wall heater. Is there a diagram that shows where we are suppose to put the lit match and which way to turn the knob? Thanks for your help
you may have to push down on gas knob to start gas flow for pilot move flame so it licks thermo couple detector.
if thermocouple gets too old it will not generated enough power to keep relay open for pilot
Nov 25, 2010 | Montgomery Ward (223600UP) Heater
How do i relight my standing wall heater light, where is it?
There should be a removable panel on the bottom front. Remove this panel and you should see gas valve with two lines going into combustion chamber. The larger of the two will be for burner and the smaller to the pilot light. There may be lighting instructions on the inside of panel,or on front of burner compartment. If not look at gas valve and see if you can see where it is marked off pilot and on. Turn thermostat to lowest setting and gas valve to pilot ,locate pilot light and hold match to it while you depress pilot button . Pilot should light. If it does hold button depressed for 1 to 2 mins. Release pilot button and if pilot stays lit turn valve to on. Turn thermostat up to desired setting and see if burner comes on. If it does you should be done. Put cover back on. If pilot light does not stay lit or burner won't light I Would recommend you call a service tech as there are several things that could be wrong. Hope this helps you.Thanks
Nov 12, 2010 | Montgomery Ward (223600UP) Heater
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
How do i light the pilot on a ward floor furnace madel 570 edr
Dec 13, 2009 | Montgomery Ward (223600UP) Heater
Nov 12, 2009 | Heating & Cooling
Wall furnace model # SFB50146B Thermal Coupler. Does it have 2 wires?
if the pilot light stays lit, but the burners don't kick on, it's a problem with the thermostat or thermostat wiring, or a problem with the valve inside the gas actuator
Oct 24, 2008 | Montgomery Ward (223600UP) Heater
Floor furnace
Dec 27, 2007 | Heating & Cooling
Montgomery Ward (223600UP) Heater Logo
539 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
Paul Carew
Mack Baxter
gbob59
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
