Question about Frigidaire FMV145K Microwave Oven
MIcrowave The door on the microwave does not close
  • netoposadas May 11, 2010
    My microwvw does not close and i need to know if i have to buy something or just upen and adjust the lacker
    New Friend:
Just rendered my husband silent with awe...quick no cost repair to door latch Fridigaire Gallery Microwave... Please watch this video posted by someone else to learn how to remove the door panel www.youtube.com/watch?v=nIdT4kS3no Gently is the key to removing the panel.
After you remove the panel, lift the latch lever until it comes unseated. For our unit, the plastic tab in the door that held the spring was broken. I opened the bottom loop of the spring slightly with needle nose pliers. Threaded the spring loop onto the right stationary piece in the door. There is a hole to hold the spring just about the level of where the broken tab was. Put the top of the spring loop back on the latch tab and reinsert the latch assembly into their holders. Popped the panel back together and it works wonderfully. A flashlight, needle nose pliers, dinner knife and someone to steady the door is all you need. Bonus, what we saved on the repair can now be spent on some family fun....
Posted on May 09, 2015
  • 958 Answers
Check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Posted on Feb 21, 2008
Microwave door doesn't close properly.
It's doubtful that it's supposed to work that way. For safety's sake, Id take it in for repair.
Mar 13, 2016 | In Microwave Ovens
Door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Feb 10, 2008 | Emerson MW8987B/W Microwave Oven
When you close the door, the system will not program , on our kenmore microwave oven. Now it trips the breaker. Why?
I am assuming that closing the door is a key to when the problem arises and will usually lead to a faulty door switch(s). The door switch must be made in order for the microwave safety circuit to be completed and let the microwave know that it is safe to operate. Door switch(s) are one repair worth making on a microwave as most other repairs are not worth the cost of the microwave oven. If you are handy you can check to make sure the switches are closing with a multimeter. Please make sure you have unplugged the microwave before attempting to check the switches. You do not need the power on to verify the closing of the door switch(s).
Aug 14, 2014 | Microwave Ovens
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
Timer changing but microwave is not turning on?
Hello :
It's a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Magic Chef MCD1311ST Microwave Oven
I have an nn2505c microwave that powers up but displays door open
Took it to a repair shop ,cannot be fixed ,no parts discontinued microwave.
Jan 19, 2010 | Panasonic NN-2505A Microwave Oven
Frigidaire FMV145K Microwave Oven Logo
414 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
