Question about Hitachi CP-X260 LCD Projector
Lamp and temp blink red - Hitachi CP-X260 LCD Projector
    Scholar:
  • 92 Answers
Check your owners manual. This means that the air filter needs to be cleaned or that the projector has become too cold. My guess is the first one. The owners manual has instructions for cleaning or replacing the air filter :)
Posted on Feb 05, 2010
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Flashing red temp and lamp lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 22, 2014 | Dukane 8912 Projector Lamp 200-Watt...
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions:
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
The red lights are blinking under lamp and temp.
did you try setting the lamp over the red light on the tv?
Jul 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
HLN5065W
there are 3 leds on the front that blink the error code. which leds blink gives you the error. if its just the standby/temp red led blinking, it has overheated for some reason. there are a couple other fans you could clean but check your ventilation. many people put too close to the wall or close it up in a cabinet. it needs atleast 4" from the wall and someway to vent out hot air and get cool air in. a different model had the temp sensor cause this issue, it is the silver thing right atop the lamp. you will have to pull the whole back panel possibly, there are two wires that hook to it and two screws holding it to the engine (lamp housing). if you get lamp and temp leds blinking, reseat the lamp door. timer and temp leds is a fan error, all 3 leds is a lamp error (lamp, ballast, colorwheel, dmd)
Dec 05, 2008 | Samsung HLN5065W 50" Rear Projection...
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
My Panasonic PT- 50LC13 doesn't turn on
Your service manual on page 82 steps you through decoding the blinking
1) there are two lights on the front near the reciever of the remote signals (Temp indicator and Lamp Indicator)
2) If the Temp indicator is on then they recommend you contact a service center
3) If the Lamp indicator is on and the power light stays on (no blinking) then you need to replace the lamp. Otherwise it says to contact the service center.
4) Counting blinks with the lamp indicator (1 every 5sec - lamp will not light or is abnormal, 2 every 5sec - lamp voltage is abnormal, 3 every 5sec - lamp temp is too high, 4 every 5sec - other error)
Apr 26, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Hitachi CP-X260 LCD Projector Logo
281 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Electro Med Services...
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
