Question about Hotpoint Aquarius WMA42 Front Load Washer
Door light no working so machine will not start
Hotpoint Aquarious WM62. Checked fuse and tried plug on another power point which I use for kettle - all ok.
I shut door and press button to start but light does not come on and the machine does not start
    Sergeant:
  • 215 Answers
Check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
Posted on Feb 08, 2010
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Error code F-05 for hotpoint aquarious washing machine
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Oct 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door on hotpoint aquarious wont open at end of wash cycle...in spite of door light OFF. Have checked drain off plug..its OK!
door catch is faulty unplug machine take off lid put hand down to door switch and pull back to open door replace handle kit
Jun 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washer stopped dead in the middle of cycle
CHECK ALSO the sensor switch underneath where the door close , you gonna need a tester for this task ,hope this helps AJ
May 05, 2008 | Hotpoint WMA13 Front Load Washer
Hi hotpoint wm62 door locked
Try "end of cycle" button & wait for 2 minutes before you try the door..........
Jan 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius model wm62
Sounds like a faulty door interlock (quite a common problem)
UNPLUG POWER first, remove lid, remove screws holding door lock in place and lift lock assembly up, replace door lock, ensuring cables are replaced in the correct order. Refit and test.
Good luck.
Nov 11, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
195 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
