Question about Ovens
Turbochef oven i use a turbochef oven at my shop and the display screen is reading,close door, but the door is already closed.cAN u please helpme
    Scholar:
  • 75 Answers
Take the top cover off and then the left and the right side.
look on the left you will see the door position switches. these most likely need replacing. easy job to do
Posted on Jan 29, 2010
Oven showing door close error with _ _ M
there are little switches inside that the door hits when you close it. open both side panels then open and close the door. you'll see them in the upper left. there primary, secondary, and monitor. PSM. they either broke or something need adjusted. easy and cheap fix. you could take the leads off and jump them until you get switches. but they are a safety feature so do at your own risk.
Jul 12, 2015 | TurboChef TORNADO Electric Oven
Fault code Close door (S) keeps coming and oven won't start
The oven is telling you that the secondary switch is not working. Either the switch is broken or the door or switches are out of alignment. the switches cost about 4 dollars. Not an expensive repair by any means.
Sep 09, 2012 | TurboChef TORNADO Electric Oven
TurboChef Tornado is showing error Close door P _ _. How do i fix this?
The primary switch is broken most likely. Take off the right cover and look past the control board and see of that switch is broken. its only a couple dollar part.
Jan 20, 2012 | TurboChef TORNADO Electric Oven
Self test oven door fail and f2 low
You need to align the door. The door is not closing properly, so its leaking heat while oven cook. Open the right side pannel. Remove the IO board ,then gently remove front visual display/soft button board. Then remove the black cap on both side Of door. Losen the oven door arm bolts (just to turns only) .Tap the door from the cennter and then tight the bolts. Reinstall everything Check that door primary switch is latching properly. If not the unscrew the switch and re align. You should be okay
Oct 14, 2011 | TurboChef TORNADO Electric Oven
Hello, I have a Turbochef tornado oven, while operation i am getting a Fault code Close door error and it keeps on coming while closing the door with a beep . Can anyone please try to resolve the error...
seems like your primary switch isn't closed correctly or it might bad.
step to trouble shoot
OVEN HAS 5000 VOLTS MOVING INTO IT PLEASE BE CAREFULL
1.press back key to turn off the oven.
2.Open left side pannel.
3.press 'back' and 'enter' key together.Then, enter 9428 and then press enter.
4.You will be directing to an testing screen.At the bottom of thetesting screen there are many alphabets.In which you can see 'P' ,'S' and 'M' .
5.Open the door and watch what happened to alphabet 'P'.I meant to say that when door open alphabet will highlited ,and when closed its seems an regular 'P'
6.open door and close the door .And also keep an eye on the primary switch at the top left corner of the oven where the door latches engaged.If it engaged very nicely and you still see an highlited 'P' in the testing screen then REPLACE THE PRIMARY SWITCH OR IF SWITCH IS OKAY THEN CHEK THE WIRING UPTO MAIN BOARD.
7.If switch doesn't latches properly then adjust switch ,by lossning the screw and aligned it properly.
PLEASE LET ME KNOW IF YOU KNOW HOW TO USE MULTIMETER,SO I CAN EXPLAIN YOU HOW TO CHECK THE SWITCH.
ALSO PLEASE RATE MY ANSWER.
THANKS
May 12, 2011 | TurboChef TORNADO Electric Oven
Hello, I have a Turbochef tornado oven, while operation i am getting a Fault code Close door and keeps on coming while closing the door with a beep . Can you please try to resolve the error and solve. Your...
DISCHARGE HIGH VOLTAKE CAPACITOR.
IF YOU DON'T KNOW THEN STOP HERE.
open left side pannel
check that the primary switch where the door lathes is closing the switch
if not then adjust it
if it is closing the switch then use multimeter and check the continuity test (hint mesure its resistance)
and if switch is bad then replace it
thanks
please rate my work
OVEN DOOR IS NOT CLOSE PROPERLY.
which subway are you , if the door doesnt close properly you may need new hinges
Jul 14, 2010 | TurboChef C3 Single Oven
This is the 3rd time for this turboChef oven - door not closed.
it is because the switch kits are not setup properly.they need to set to open and shut in the right order,hope this helps regards lse
Jan 16, 2009 | TurboChef TORNADO Electric Oven
Ovens Logo
91 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
